Clutch Noise
08.05.2020 18:35 # 1
thejackal44
Hello friends;
When you press the clutch for 2 days, there is a sound with the engine sound, when you pull from the clutch, the sound decreases and continues like the noise. In addition, when I press the clutch with the sound, I feel an unusual vibration as if it is moving under the clutch and running away. They call it a dutch clutch but.
Thank you I am already waiting for the comments of expert friends.
By the way my car is 2002 peugeot 307 1.6 petrol + lpg
08.05.2020 18:35 # 2
thejackal44
don't anybody have similar problems
08.05.2020 18:35 # 3
samet206
Clutch ball can be noticed when the vehicle is not working or running, but in order for you to hear the sound more comfortably, when you press the clutch, does it sound like a cat sound?
08.05.2020 18:35 # 4
DeRyCK
I also have the opposite situation, when the clutch presses the sound of the engine improves.
08.05.2020 18:35 # 5
thejackal44
He was fine too
08.05.2020 18:35 # 6
fætih
It is likely to be a prizdirek ball. the same sound I have in me is cut to pressure. pressure + ball improves.
08.05.2020 18:35 # 7
thejackal44
are there any other friends who have had the same trouble, and what would be the estimated cost, thanks
08.05.2020 18:35 # 8
osman_bora
I have the same situation, but it is not a problem for me. It has been in the same way for 2 years. Or is it normal to be like that, you have to look and look side by side with the same vehicle ..
08.05.2020 18:35 # 9
thejackal44
2 years how it did not cause trouble, interesting
08.05.2020 18:35 # 10
efesbright
Well, brother, I had a similar problem. the vehicle sounded like crazy when it pressed the clutch. as if the plate was rubbing against the ground. .
I took the industry, whether the pressure is lining or not.
gearbox oil out. nobody noticed while doing maintenance. secromençler or something changed.
The sounds at this grip point need to be taken seriously.
Let a master ride a car first. he probably understands what happened ...
I think my expense is 2000 TL. not authorized, in particular, secromençler or workmanship is all 2000 thousand TL go if it matters a little bit.
08.05.2020 18:35 # 11
thejackal44
Thank you brother, thank you.
08.05.2020 18:35 # 12
fætih
If the pressure to the clutch increases, the trouble is great. the gearbox cannot be removed from the pressure.
but if the sound is cut when the clutch is pressed, the ball is defective. it doesn't cost much. Whenever the raid ends, you change it.
08.05.2020 18:35 # 13
thejackal44
Thank you bro
