Clutch is still a problem
08.05.2020 21:03 # 1
Emirseng
Hello friends, I have posted the clutch problems of my vehicle before. I replaced clutch linings and clutch wire. The problem was with the clutch wire and the ball inside the pad. Now the problem is, after I pull my intermediate foot from the clutch, it sounds like a click, and the sound goes away when I press the gas. The same sound began to play while working. The moment I start, it works with that voice. As soon as the vehicle starts, the sound goes off The master threw the gearbox again. He installed a new clutch pad, but the sound continues again. Why might it be sourced? Has anyone happened before?
I also routed the vehicle at the same time. At this time, the gear shifts incredibly, and the same shudder is in the vehicle while driving between 70 and 90. I brought him to build the vehicle, but this time there were different problems.
Can you support this kind of situation when it lives?
08.05.2020 21:03 # 2
x571
[QUOTE = Emirseng] Hello friends, I have posted my car's clutch problems before in the forum. I replaced clutch linings and clutch wire. The problem was with the clutch wire and the ball inside the pad. Now the problem is, after I pull my intermediate foot from the clutch, it sounds like a click, and the sound goes away when I press the gas. The same sound began to play while working. The moment I start, it works with that voice. As soon as the vehicle starts, the sound goes off The master threw the gearbox again. He installed a new clutch pad, but the sound continues again. Why might it be sourced? Has anyone happened before?
Can you support this kind of situation? [/ QUOTE]
the clutch bearing, the socket post bearing should be replaced, especially if the vehicle is not depressed when the vehicle is not engaged. If you say there is a problem, it doesn't. If the 3 cents bearing is the master man who will change it, it changes it when replacing the pressure pad. because it has a lot of workmanship. If you want to shoot a video again put it here maybe I misunderstood.
08.05.2020 21:03 # 3
boruc
Shifting between 70-90 km and head shaking of the vehicle are caused by axles. I wonder if something was wrong while stuck in the axles
08.05.2020 21:03 # 4
Emirseng
I'll make you look at the sound again. At any moment, the sound comes when you press the clutch. The sound goes away when I press the gas, even if I am in gear or when it comes to sound. In case of a drive, there is no problem, as soon as I hit the gas, the sound goes out immediately. However, when I pick up the vehicle, if there is a sound, I have to press the gas at that moment so that the sound goes away.
08.05.2020 21:03 # 5
As there is a problem with workmanship, it is really hard to find a good master, as our teacher friends say, get well soon. I hope your problem will be improved.
