Clutch is held down
08.05.2020 16:57 # 1
06OzGuR06
Hello everyone, thanks for your answers in advance.
There is a situation I have encountered in the last days. When I press hard on the clutch, the clutch pedal remains depressed at the bottom. When I pull the pedal with my hand, the pedal comes up. It doesn't always happen. Just press the pedal hard. . I suspect the clutch wire but if there is a different situation, I ask you to share your information.
Vehicle partner adventure 2.0 HDİ 06ÖzGüR06 2012-08-05 14 : 17: 08
08.05.2020 16:57 # 2
sezar206
It is probably the clutch rope. it was happening to me too, it was stuck, the bow wanders around as it snaps when shifting gears, or that sound was coming. I went to you, I was dismantled, it was engraved. Van Pejo service brought the new tee from France. / 0 tlmi was something like that. You can easily find it in Ankara. Look at it as soon as possible, if it breaks down on the road, your vehicle will stay where it is, you cannot change gear.
08.05.2020 16:57 # 3
What is a vehicle? Please share it in your signature information.
08.05.2020 16:57 # 4
heavci
The same problem happened to me when BendePartner was present. The problem was with the clutch wire. It changed when I changed it.
08.05.2020 16:57 # 5
06OzGuR06
Vehicle 2007 dating adventure 2.0 HDI friends.
08.05.2020 16:57 # 6
heavci
[QUOTE = 06ÖZGüR06] The vehicle 2007 partner adventure 2.0 HDI friends. [/ QUOTE]
As I said, then when you press it, it will be pressed down and if it does not overlap, you will need to change the clutch wire. Because it was in my partner. He was doing it occasionally, not constantly. Also, my advice is not to have wire industry, I had it installed and it lasted for 1 month. "border =" 0 "alt =" Dead "title =" Dead "/>
08.05.2020 16:57 # 7
06OzGuR06
[QUOTE = heavci]
[QUOTE = 06ÖZGüR06] Vehicle 2007 partner adventure 2.0 HDI friends. [/ QUOTE]
As I said, when you press it, it stays down and you will need to change the clutch wire . Because it was in my partner. He was doing it occasionally, not constantly. Also, my advice is not to have wire industry, I had it installed and it lasted for 1 month. "border =" 0 "alt =" Dead "title =" Dead "/>
So let's change the clutch wire without losing time, your comments thank you guys.
08.05.2020 16:57 # 8
sahin-peugeot
Make sure to replace the clutch wire & nbsp; and the fiber, otherwise make sure that the parts that break off again & nbsp; are original & nbsp;
