clutch hk
08.05.2020 16:36 # 1
guney3510.
Hello friends, I have a little problem in my car
, but it was stuck in my mind whether it is a harbinger of something; if I don't leave the handbrake when I leave the car in reverse gear even on a slightly inclined ramp, does the car slip? If you have an idea, I'd appreciate it. thanks in advance.
08.05.2020 16:36 # 2
djchaos
If your car slides down or moves normally, if it does this in normal gears then your vehicle's compression is weakened, but it is normal to slip when parked in reverse gear.
08.05.2020 16:36 # 3
guney3510.
I'm just dying too, I'm getting cold on the sidewalk so that the hand brake doesn't freeze.
thank you.
08.05.2020 16:36 # 4
djchaos
In cold weather, the hand brake freezes, most people leave the vehicle in gear and park it. It is absolutely necessary to chock a vehicle under the vehicle that is parked in the gear. It is valid in forward gear, not in reverse gear. If your car's compression is weakened, it moves in forward gear. As I said, there is no problem in moving in reverse gear.
