Clutch Hardness
08.05.2020 17:33 # 1
reality59
Friends, I use 2004 HDI XR Peugeot 307, I realized recently, I did not realize that my clutch was not very hard because I did not go into the city very hard. I stayed my left leg muscle, so I could press the clutch. clutch is not at the very bottom but slightly close to the middle, I sprayed the liquid gress oil on the clutch pedal, it softened slightly, but still, like other vehicles, it escapes into the pressure of the pedal in other vehicles. I wonder why? Is my clutch set starting to go slow? vehicle at 150,000 km.
08.05.2020 17:33 # 2
reality59
Did you forget me :)
08.05.2020 17:33 # 3
rolandgarros
vala they forgot LOL
08.05.2020 17:33 # 4
KenBlockJR
1.4 diesel 307s pretty hard clutch pedal.
like normal
08.05.2020 17:33 # 5
tazmaniac
ah istanbul, we ate our lifetime, we are entering that traffic every day :)) not to darken it, but when the pressure changes, the clutch is like a bird ... my car is gasoline though. I changed it in. I even use linea, fluence or something in the workplace when I get down from it and get on my own car, I say oh oh there is a world
08.05.2020 17:33 # 6
elsoberano
My clutch also happens when the hard pressure pad approaches the last bits of its life. Of course, sometimes there is no solution when the clutch changes. I have a friend's 307 room complained of clutch stiffness, changed the pad to now it was as soft as possible.
08.05.2020 17:33 # 7
samet206
Clutch is running out.
If the clutch engages higher than before
Engine speed is increasing but speed is not increasing
If the gear shifts have difficulty, the vehicle moves later than before
There are many more reasons and situations of control, but if it is hardened, it is biological.
08.05.2020 17:33 # 8
reality59
[QUOTE = samet206] Clutch is running out.
clutch engages a little higher than before
engine speed increases, accelerates late
There is a difficulty in shifting gears, no change compared to the old one: D
I approve of what you said, I think the way of the master seemed to me :)
08.05.2020 17:33 # 9
rolandgarros
exactly the way the master looks Unhappy
08.05.2020 17:33 # 10
tlp
If you change the clutch set, it will return to normal
Probably (which is certain) is about to end
It is useful to change it without overcoming different problems
Be very careful when first pressing the clutch first time after replacement
Since it will be very soft compared to the old one, do not damage the base :)
08.05.2020 17:33 # 11
samet206
[QUOTE = reality59] [QUOTE = samet206] Clutch is running out.
It is a little more, we confirmed the problem more or less, but don't worry, this is how arabism works. Sometimes it does happen, overwhelms people, but there is nothing else to do arbitrarily. You should do more as soon as you are fit without shifting the gearbox and putting yourself into trouble.
08.05.2020 17:33 # 12
aknakn
Since the clutches are hydraulic, I would like to look at the hydraulic oil. Maybe it may have hardened from it, it was pressed in my previous vehicle.
08.05.2020 17:33 # 13
reality59
thank you all for your concern God bless you :)
Today, I went to the master and looked at the show, "Nothing, we will manage it for a while, we will change it later." He thanked and got the price, gave 500TL price Clutch Set + Workmanship How do you think the price?
