clutch finished
08.05.2020 15:13 # 1
ask307
friends went to the service in the morning about low traction and fuel, the master showed officially, the speed of the car does not match, the vehicle is shouting but it does not go clutch is on top of it said in the fuel about it said that now you will burn at least 30% more fuel, original clutch team 230 TL labor 150 TL
08.05.2020 15:13 # 2
sercinho
get well my brother will be a monster after maintenance lion's hope
08.05.2020 15:13 # 3
volkan_uysal
Get well soon, I will ask you to share the result after maintenance ...
08.05.2020 15:13 # 4
ask307
thanks guys, thank you very much. I will definitely share there is a significant loss of power because in the car
08.05.2020 15:13 # 5
Serhun
I would recommend replacing the clutch as a set with its pressure and ball, to get past, so as not to cause problems in the future. At the end of the process, you will see the obvious difference, but after 1000 km on average (for the pad to get used to)
