Clutch engages
08.05.2020 20:59 # 1
Emirseng
Hello, the clutch has started to be installed in my vehicle during gear shifts. I press back, I don't come back and get stuck, I had a big accident today because I couldn't do gear shift. Since it gets stuck every once in a while, the iron sounds like a click. Why might it be caused?
08.05.2020 20:59 # 2
there may be several reasons for this. clutch fork - rope - thrust pad - clutch center.
08.05.2020 20:59 # 3
GokhaN
most likely I suggest you change your trouble both on the wire or fork are not very expensive parts
08.05.2020 20:59 # 4
x571
[QUOTE = Emirseng] Hello, my clutch has started to be installed during gear shift in my car. I press back, I don't come back and get stuck, I had a big accident today because I couldn't do gear shift. Since it gets stuck every once in a while, the iron sounds like a click. Why might it be caused? [/ QUOTE]
sometimes there are such problems due to the mat, I have lived 2 times. The problem was fixed when the mat was thrown.
08.05.2020 20:59 # 5
Selcuk55
The only reason to stay stuck is the clutch is one of the upper centers, most likely it is the upper center. Using the half clutch or foot on the pedal
08.05.2020 20:59 # 6
ismailkaya
If the situation is good, look at the clutch set and replace it completely. Make your priority choice at the service.
