clutch clutch shortage
08.05.2020 16:51 # 1
rhcpeppers
friends, when I press the clutch lately, it sounds like a click. Latch type & nbsp; I think there's something going on. I press it a few times so it doesn't throw it rhcpeppers 2012-06-08 23:42:56
08.05.2020 16:51 # 2
sahin-peugeot
there may be a problem with the clutch wire, or it may come from the spring under the pedal
08.05.2020 16:51 # 3
falan
the spring under the pedal is probably a dandel .. If you apply light grease, it should be improved .. but & nbsp; & nbsp; If you feel trouble on the clutch wire, you should definitely change it .. very important !!!
08.05.2020 16:51 # 4
smilyben
Hello
I had the same problem. I changed the clutch wire and the problem was resolved.
