Clutch clutch close to release
08.05.2020 18:20 # 1
umutgny
Hello friends just joined you 2 days ago, the peugeot 307 comfort 1.6 hdi 110 bg make-up case grasped the top of the clutch in my car close to releasing the clutch. They say the clutches of the 307s are very sensitive, is this normal? vehicle at 158 thousand umutgny 2014-02-25 10:36:35
08.05.2020 18:20 # 2
[QUOTE = umutgny] Hello friends just joined you 2 days ago, the peugeot 307 comfort 1.6 hdi 110 hp make-up case grasped from the top close to releasing the clutch in my car. They thought the clutches of the Peugeot 307 are very sensitive. Is this normal? vehicle at 158 thousand [/ QUOTE]
When you buy it, it is always heavy maintenance, new tires are already made, the car does not reduce oil water, there is no play here, they do not mind the cost.
08.05.2020 18:20 # 3
umutgny
Well, how do I look for this job, the pads are finished, you said that the pressure has just changed the pad. There is no lineage in the fuel of the car. The city burns 5.5 km in 100 km but this pressure has bothered me.
08.05.2020 18:20 # 4
mistercasper
dude second hand vehicle work like this unfortunately ... you can never mind what the man says first change your oil and water filters (maintenance in the diesel vehicle is important) then check brake pads and discs pressure pad if it is not an adjustment, it is already finished to miss I guess the room gradually gets to the max, including workmanship max 500 ...
08.05.2020 18:20 # 5
umutgny
Thanks for your answers, what do you think the clutch of these peugeout 307 dies is very sensitive? Where does the clutch grip on your vehicles?
08.05.2020 18:20 # 6
mistercasper
I don't think there will be much difference with my vehicle 407 but 307, my clutch is gripping in the middle ... yes, I think the pressure pad runs out a little early in the pejo, the room is not very sensitive or even in the worst conditions, it goes at least 50 thousand km and its normal average is around 100 thousand. ...
08.05.2020 18:20 # 7
umutgny
I know the clutch hydraulics is the truth of the 307s so I know the clutch cannot be adjusted.
08.05.2020 18:20 # 8
[QUOTE = umutgny] Well, how do I look for this job, the pads are finished, you said that the pressure has just changed, the pad has just changed.
In addition, I would like to mention that, if you do not buy a car from your uncle, your uncle, whoever you buy the car, you should definitely buy between 500 TL and 1000 TL in vehicles between 10-30 thousand TL. charges
08.05.2020 18:20 # 9
pusutr
When I first bought 206, debyrement grasped from the top.
He said to the crank pulley that he was making a noise. We have completely replaced the crankshaft bearings and belt.
No sound was interrupted, but the clutch is back to normal.
I asked my brother, he has a setting somewhere he said.
Whatever my master did now ...
08.05.2020 18:20 # 10
umutgny
I used to grip the clutch in the middle of the vehicles I used, but in 307 I almost pull it up to the end of the clutch and grasp it there, and when I put the gear in 1, hold the car and pull it out of the brake, my foot is back on a very low slope. . umutgny 2014-02-25 17:59:13
08.05.2020 18:20 # 11
barishrocker
In the grip, it does not miss back, and even the car is driven forward slowly. Not too high. I can say that the polo grasps above and the clio below. If the car is thrown forward while pulling from the circuit, it is also a sign, but I guess yours has even exceeded that phase .. Ask the service they will tell you ..
By the way, didn't you show it to the service when you bought the car?
08.05.2020 18:20 # 12
umutgny
I showed it to the biker, he said no problem, not normal, but this is the point of grip. umutgny 2014-02-25 18:47:42
08.05.2020 18:20 # 13
pusutr
[QUOTE = umutgny] On the vehicles I used, he clutched the clutch in the middle, but in 307 I almost pull it all the way to the end of the clutch and he slips my foot when I put the gear 1e, hold the car in the grip and pull it out of the brake. even need to be taken forward. [/ QUOTE]
Then there is a problem with the press pad, sir.
08.05.2020 18:20 # 14
umutgny
I am so cramped at this point of view. Bid this printing pad job came out. I bought 307 after 2 days later because honda city was very burning in my previous car, but I got 307 in this but this cost is also.
08.05.2020 18:20 # 15
barishrocker
My vehicle 307 is diesel .. As I said, if we compare the polo above and clio below, we should not miss it in the grip. If you keep it in the right place.
08.05.2020 18:20 # 16
umutgny
I showed the master to the vehicle. One of them tried to install and remove the handbrake with the back of the vehicle, the back of the vehicle collapsed, tried to move on and the pressure was exhausted.
He tried to lift the hand brake with the 4e in 4 masters, tried to lift the car stopped 2 times. There was no kidnapping.
He said that he could fix it, but if the pressure changed the pad, after a while, the grip point would rise up again.
08.05.2020 18:20 # 17
ahmet_bjk
Grasping in the middle at 308
08.05.2020 18:20 # 18
koramiral
there is bbende206, just like yours, it does not have any problem, it is an attacking pejolar, it has a special feature, they said that they have no problem.
08.05.2020 18:20 # 19
umutgny
Is there a setting for this, friends, I don't enjoy driving like this, it doesn't seem normal to me. This is top grip. If you use 307 diesel friends write clutch clutch points, we will have a healthy idea.
08.05.2020 18:20 # 20
tadiyokartik
Hi my friend,
There are a few possibilities in this situation that I have encountered so far.
1-Did you check the clutch wire? Sometimes it is close to rupture. He may be taking it at the tip.
2-Is the clutch stripping? There are several ways to understand this. The masters have already tried with the handbrake method, such as the smell of coercion, the inability to find the cycle, the car does not allow you to change gear, not to exceed a certain speed, etc. If you hit the ramp, the spirit of the car will be obvious.
I say this by saying that we have a Japanese car with a very sensitive 300,000 knob clutches of Japanese cars such as 3-petrol cars (city). Pejoes have a slightly different clutch system.
