Clutch clutch
08.05.2020 14:02 # 1
erden1978
My 106XN model car has a drain clutch above. I asked a couple of masters and the workshop.
08.05.2020 14:02 # 2
Ismail
I am sure you will answer the problem if you open the meet wedge. ..
08.05.2020 14:02 # 3
GokhaN
If I don't remember wrong, it can be adjusted with the adjustable wire used in Citroen Saxo.
08.05.2020 14:02 # 4
hasimayaz
Saxo vts can be adjusted if you install the wire. The wires in the 106s must be installed so no adjustment can be made.
08.05.2020 14:02 # 5
Emin
My wife, harun card, told me that saxo wire plug die but I couldn't
If I can change this weekend, I will tell you, I have the same problem :)
08.05.2020 14:02 # 6
HakanGokdemir
I had the previous 206, this problem is now at 306m. Is there a solution for mine? This is probably the general problem of Peugeot LOL
08.05.2020 14:02 # 7
haruncoskun
I have had the same problems with the saxo vts wire.
08.05.2020 14:02 # 8
okan77
it is shorter than it should be installed saxo deb.teli ... it should be between 45/50 TL ...
08.05.2020 14:02 # 9
HakanGokdemir
[QUOTE = haruncoskun] With the saxo vts wire, I came to the desired consistency and I had the same problems [/ QUOTE]
So is this valid in Harun 306?
08.05.2020 14:02 # 10
haruncoskun
[QUOTE = hakan1203] [QUOTE = haruncoskun] I have the same problems with the saxo vts wire [/ QUOTE]
Brother I don't know if I sleep 306
08.05.2020 14:02 # 11
erden1978
Is this the authorized service?
If we put the wire in trouble.
08.05.2020 14:02 # 12
haruncoskun
[QUOTE = erden1978]
No problem, take the wire, I will wear it, I will be in Ankara at the weekend
I haruncoskun86@hotmail.co Wink
08.05.2020 14:02 # 13
erden1978
[QUOTE = haruncosk a] [QUOTE = erden1978]
I will see you in the evening. Angry
