Clutch ball-to-socket fault |
| 08.05.2020 19:18 | # 1 |
| 08.05.2020 19:18 | # 2 |
madblueblacksea |
If you are driving, try it without wasting gear. If the sound is cut, it is highly probable that the ball is pressed. I can not say something for 600 TL, they are reducing the gearbox with varying prices of 200-300
| 08.05.2020 19:18 | # 3 |
I have the same problem, and 600 or so. I have researched this problem for this problem. In fact, the voice has increased even more recently. He's giggling.
| 08.05.2020 19:18 | # 4 |
I made it changed and changed it to 2 balls. one, a small one, big originals, big 70 and small, 50 transmissions have to come down. I gave 200 workmanship, while I had it disassembled, I changed it to the printing pad, 280 TL printing pad set. but do not change the oil 1 month later, I changed the oil, light crowing began. It's not a ball sound. I asked for the old oil shifting in small parts spilled from the gearbox gears, so it happens in most cars 140 in vehicles after 150 thousand. I contributed and started to be cut. only ball exchange costs between 300 and 400 it makes more sense to replace the printing pad, you will not give any more workmanship. 280 press pads and socket ball balls all hold between 600 and 700.
