Clutch assembly
23.04.2022 11:14 # 1
x571
When you press the clutch, there is a clicking sound as if a spring is stuck, vibration is felt in the pedal. sometimes it gets stuck and you have to pull it by hand. what does this mean? Could there be something to lubricate in the pedal section?
25.04.2022 17:30 # 2
Have a look at the clutch center and clutch fork bro. If it has lost its spring feature, look at the pedal inside the clutch.
26.04.2022 17:16 # 3
x571
How do we know that the spring has lost its property? Hearing the word gets stuck, the wire says it will change, the part price is 900 Angry
26.04.2022 17:48 # 4
If you can remove the wire, remove it yourself bro, I say squeeze wd40 into it well. 900 TL ne yaw
