clutch after replacement clutch set
08.05.2020 20:30 # 1
x571
mmerhab to
The vehicle's clutch set has been changed. He used to grasp the following, now he starts to grip in a middle-upper place. Is this normal. I am having a hard time grabbing it. If the grip point changes, will it get rid of it in the future.
08.05.2020 20:30 # 2
x571
Topic is up to date
08.05.2020 20:30 # 3
tsufrankwoli
Since it is new, it can be changed normally, but I think it remains. When he uses a little more, he approaches the old point.
08.05.2020 20:30 # 4
x571
[QUOTE = tsufrankwoli] Because it is new, it can be changed normally, but I think it should stay. When he uses a little more, he approaches the old point. [/ QUOTE]
Changed 7 thousand km. The master gets used to it, he said bea, but still grasps from above. Why did it happen? I don't get annoyed, then my head tumbles.
08.05.2020 20:30 # 5
Snrzrl
If you say I could not go to the master again, he did not want to drop the pedal.
08.05.2020 20:30 # 6
OguzhanKucuk61
[QUOTE = x571] [QUOTE = tsufrankwoli] It can be changed normally because it is new but I think it remains. When he uses a little more, he approaches the old point. [/ QUOTE]
Changed 7 thousand km. The master gets used to it, he said bea, but still grasps from above. Why did it happen? I don't get annoyed, then my head tumbles. Some of them say Peugeot grasps from the bottom when the pressure is over. Who says nothing? [/ QUOTE]
He is making up such a generalization. When my pressure was over, it was gripping up and the pedal was firm. When he changed, he started to grasp the middle bottom. And the pedal got so soft. Your master probably tried to accustom you to the new version of the clutch, not the car. Get well soon
08.05.2020 20:30 # 7
x571
[QUOTE = OguzhanKucuk61] [QUOTE = x571] [QUOTE = tsufrankwoli] Because it is new, it can be changed normally, but I think it should remain. When he uses a little more, he approaches the old point. [/ QUOTE]
He is making up such a generalization. When my pressure was over, it was gripping up and the pedal was firm. When he changed, he started to grasp the middle bottom. And the pedal got so soft. Your master probably tried to accustom you to the new version of the clutch, not the car. Get well [/ QUOTE]
I found something to say from posts on forums other than the net
Clutch pedal adjustment (by tightening and loosening the bolt just above the pedal) but no clutch pressure adjustment.
I think it's gonna be pedal adjustment
08.05.2020 20:30 # 8
x571
[QUOTE = Snrzrl] I did not want to go to the master again and try to drop the pedal if you couldn't get back to work [/ QUOTE]
Is there any harm in using it this way?
08.05.2020 20:30 # 9
taksicicocuk1
When the friends get close to the end of the pad, when it is finished, it comes to life, because it does not find anything to grasp and it misses the car, it can not take off from the gear, it will stay on the road. /smiley18.gif "border =" 0 "align =" middle "/>
08.05.2020 20:30 # 10
taksicicocuk1
it won't hurt because it should be
08.05.2020 20:30 # 11
karaca61
3 days before the feast of Ramadan, I was on the hill, before the end of the print, the situation before the end is very hard and it is grasping from above. Manıfolt CLEANING I went out, the engine landed and the ring will be collected from the day. 307 1.6 hdi 246.000 km. I am the first owner.
