clutch
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 19:38 # 1
estidegeldim54
hi friends, if anyone knows, I would appreciate if the clutch pedal was wasted with a breaking sound. I would appreciate if anyone who knows that the upper center is the bottom center or the lower center is the fatty running model has broken information on my clutch wire, the clutch pedal is currently idle.
08.05.2020 19:38 # 2
koray.turan
the wire may be broken
08.05.2020 19:38 # 3
estidegeldim54
Well, do you know the center upper center lower center entering the transmission?
08.05.2020 19:38 # 4
koray.turan
my more knowledgeable brothers will help if i want to mislead you
08.05.2020 19:38 # 5
estidegeldim54
thanks, if you have any information, I would be glad if the car is on the way, I will order the parts accordingly
08.05.2020 19:38 # 6
samet206
It is very likely that your clutch wire was broken and I experienced the same things you said, I changed the wire, the problem disappeared. But in 406, I don't know how much the situation is.
samet206 2016-02-11 00:03:09
