clutch
08.05.2020 19:39 # 1
fatihc88
Selamin aleykum gentlemen, I just bought my car and put it into service, the press changed the pad, the ears changed, changed the oil or something, my car did not get 206 x desing gasoline LPG. when I press it a little bit of clutch on the departure, the smell comes from the car.
08.05.2020 19:39 # 2
koray.turan
If the press is new to the pad, the sound may come from immo because you have a normal clutch at the bottom, so you can do a half clutch.
08.05.2020 19:39 # 3
fatihc88
The printing pad is new, so you say it is sitting down then what is immo over time?
08.05.2020 19:39 # 4
samet206
Even though the pressure pad is new, the 206 clutch structure is not a tool that grips at the bottom, but it generally grips at the top. If it doesn't eat, it stops. You can consult something adjustable. I couldn't see a serious problem in the article I read.
08.05.2020 19:39 # 5
koray.turan
[QUOTE = fatihc88] The printing pad is new just so you say it is sitting down then what is immo over time? [/ QUOTE]
The beep beep that sounds when the door is opened while the key is in contact after the vehicle is stopped is immo source
