Clock reset on the console
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 20:46 # 1
Mehmet UYAR
Hi friends, my partner tool has run out of battery by knocking it, I have to press the reset button on the console because the electricity is cut off and the electricity is cut off, but I am not working.
08.05.2020 20:46 # 2
maximusti
holding the button on the left should enter the setting menu, doesn't it react to pressure?
08.05.2020 20:46 # 3
Mehmet UYAR
I pressed on the left and right but on the right, but it did not react, let me try and hold it then I hope it will improve and the screen will blink, constantly adjust me
08.05.2020 20:46 # 4
Mehmet UYAR
Now I went, I tried what you said, I set the time and date, thank you for the information you gave, I will have two more questions. When the doors are opened, I do not know if it is writing in English on the screen, but whether this is Turkish or not, in another question, the battery related to the battery again turned off before the battery was exhausted and the screen went off. now it turns off when the ignition is on, but the screen is not extinguished, do we have the chance to do this or will it not be fixed without connecting to the computer? tape is not original
08.05.2020 20:46 # 5
maximusti
[QUOTE = Mehmet UYAR] Thank you for the information you have given, I have tried and went to the time and the date. I have two more questions when the doors are opened. the tape was completely closed and the screen was extinguished now it is still off when the ignition is on but the screen is not extinguished, do we have the chance to do this or it will not fix without connecting to the computer tape is not original [/ QUOTE]
When it was reset, it changed the language setting. Again, on the same screen, the language can be adjusted by pressing and holding the keys,
If there are two lines, if there is Turkish Support, there are three lines,
English is called "Language", French is called "la langue",
you can re-enter that menu and change the language.
08.05.2020 20:46 # 6
Mehmet UYAR
I did what you said, but I don't support Turkish language, I did English now
