Clicking sound from the trunk
08.05.2020 19:08 # 1
ginesis80
Hello friends 1.6 hdi 110 hp I had a comprehensive maintenance 2 days ago. sounded a lot of front shock absorbers z rods brake discs. Changed the voices in front. The torsion bushings in the back were also cracking, and we changed them, the shock absorbers were intact. But when I enter the pits in the back, there is a sound like plug and play, I unloaded the luggage, laid the seats, glued the blower blowers, but I would appreciate it if anyone has experience to make it futile thanks.
08.05.2020 19:08 # 2
talip206
There is a round cap in the middle of the jantine. Sometimes that cap loosens and falls between the rim cover, hitting the rim in the pits and making sound. Or it could be the jack inside the spare wheel. The master would have noticed if there was a glitch because he was new in this regard. That's why these things came to my mind
08.05.2020 19:08 # 3
ginesis80
As you said tomorrow, I can take the jack out with the spare wheel and try to make a luggage lock. They shared it on the internet.
08.05.2020 19:08 # 4
tuncaysahin
Hi, that sound is coming from me as if it was coming from the disc, I changed the zodiac rubber wedges, but it is coming again
08.05.2020 19:08 # 5
fxmen
Check the lock of the rear trunk of the friends, the piece above might have become loose.
08.05.2020 19:08 # 6
berk2309
If your trouble is a lacquer, but the sound is sound, if the shock absorber leggings fall into the dump, it is upstairs I put it on the nest, that sound is boring.
08.05.2020 19:08 # 7
samet206
If it is a whirring sound, change the luggage lock counter you are talking about.
08.05.2020 19:08 # 8
Antiseptiq
I have been having this problem for 1 year, first I thought of it as a fire extinguisher, I removed it, I said it was spare tire, I removed it, when I say so, there is still nothing in the trunk for 1 year, 2 times went into service, 2 of them said different things, 2 services different things I did not make it to say, because they said uncertainly, for the last 2 months, the baggage has been opened or locked, I wonder if it can be from the baggage, I hope so ... Antiseptiq 2015-03-13 00:30:57
08.05.2020 19:08 # 9
cnrars
I have the same problem, I tested with a friend today, there are labyrinth sounds on bad roads, especially on parquet roads, I lowered the back seat, removed the pandytosis, there is sound coming from somewhere, but I do not understand where the sound is coming, I ate the head, I will eat, I will try to fix the rear shock absorber bellows, I will sit in the trunk and listen to the sound.
08.05.2020 19:08 # 10
Canberk35
Look at the bellows of the rear shock absorbers. If they are not fixed, they fall and make noise on rough roads.
-If the problem is not blowers, it is most likely that it comes from the lock mechanism. It may not fit properly or pinch.
-If it is not locked, something that is in the trunk may make a sound by shaking it somewhere. If necessary, unload all luggage and try it.
08.05.2020 19:08 # 11
rkalkan
.... the rkalk 2015-10-31 09:13:00
08.05.2020 19:08 # 12
biccci
I have the same trouble and probably melted the plastic piece in the middle of the trunk lock.
08.05.2020 19:08 # 13
swing67
I have the same problem, I hear the sound from the right side as a plug and play. There is nothing left until the dismantling of the seat, sponge, shock absorber, chock, rear belt, plastic parts of the trunk. As if the sound comes from the ceiling behind the seat behind the driver's seat. I was surprised where to turn now
08.05.2020 19:08 # 14
swing67
I wrote wrong, left back.
08.05.2020 19:08 # 15
ondoz
Guys, I used to click the clicker from the back where the sponge was attached. I took the sponge out and brought it home. When I carefully opened the place (corners) where it was attached from the joints, I saw that the substance like hard rubber was deformed. I put a suitable sponge there and sew the fabric. I put the sponge on my car again. The click from behind was cut off. Good luck with.
