Clicking after 307 engine stop
08.05.2020 18:07 # 1
yusufsemi
Hello friends
About 30 seconds after I stopped at 1.6 gasoline 307, it sounds as if the plastic gears are not fully grasped. I hear a very subtle sound when I stop the vehicle. After a while, the sound stops and clicks and takes 4-5 seconds. I followed it on the airway after the air filter comes from where the air enters the engine.
What could this be?
my yusufse 2013-12-07 00:17:38
08.05.2020 18:07 # 2
yusufsemi
I tried 4 times this morning. The sound was cut off. Still, I went to the master and explained the problem. There was no sound he tried. There was an air butterfly after the air filter. Is that what makes the sound? He said the weather was suddenly cool. For now, no problem, apparently. Let's see what time will show
08.05.2020 18:07 # 3
Burak
I hope it will not be better.
08.05.2020 18:07 # 4
qqyyxx
[QUOTE = yusufsemi] Hello friends
What could this be?
As far as I understand the sound you have described, I could not remember the full name of the turbo pressure valve or egr valve, now I guess it sounds like it comes from that part. Try to match the sound of a master who knows the psa engine. he will understand the piece that I say. The part I mentioned is adjusting the turbo pressure. If it sounds bad when it breaks down, you can hold the bulging balloon with both hands and take off the air or something similar to it.
