click sound from steering wheel help ltf
08.05.2020 14:01 # 1
beddri
first of all thanks to friends who shared their knowledge and knowledge.
I have not been running the car 1.6 206 xt for 3 weeks. When I finally looked at the plus hood and where it came from, it seemed as if the hid system was coming from there.
08.05.2020 14:01 # 2
haruncoskun
In my opinion, since the load on the pump is over, the engine speed is rising, if there is an open air filter, there may be a sound from it.
08.05.2020 14:01 # 3
sinan-s
[QUOTE = rebellious] I think, because the load on the pump is increasing, the engine speed increases, if there is an open air filter, there may be sound coming from it .
Interesting Confused
08.05.2020 14:01 # 4
Ismail
I do not know, but it will help soon
08.05.2020 14:01 # 5
that sound comes from me, sometimes go to the service and find the solution as soon as possible;)
08.05.2020 14:01 # 6
beddri
it is not such a mild sound, it is obvious that I have noticed that where the sound comes from, the air filter did not come from there, the steering wheel hyd system came from there, I looked at the hydraulic oil and the color of the oil is in good condition but it is annoying.
08.05.2020 14:01 # 7
sometimes it can make itching on the itching roads ..
08.05.2020 14:01 # 8
hasimayaz
Generally, this sound comes from every vehicle when the engine is cold. Does the vehicle arrive when it's hot? Also are you sure it's from the pump? There are 2 reasons that can create such a sound. First, the power steering oil is depleted.
You should follow the source of the sound well.
08.05.2020 14:01 # 9
IsmailAtes
The same problem happened to us in our kango, they do it from steering hydraulics and if you have a familiar service, they handle an average of 100 liras.
08.05.2020 14:01 # 10
48-gti
The steering box's bellows can be exploded, drilled, makes a hissing sound when turning left and right.
08.05.2020 14:01 # 11
cerci07
that sound is normal, when almost every power steering car turns right or left, it usually gives that sound in the tour presentation.
08.05.2020 14:01 # 12
HakanGokdemir
I had the same problem, it was 206 xt in my vehicle and at the authorized service they replaced the steering pump for a price of close to 600 TL. I paid it to the seller because I encountered it when I bought the vehicle. I can say that the pump can be repaired, it is likely that it can come from the pump's pulley. you can stay ...
08.05.2020 14:01 # 13
beddri
I ran the engine for about 10 minutes, went back and forth a little bit but still going
08.05.2020 14:01 # 14
beddri
There is a 3.5 mm spiral with 16 inch cant, is there any possibility from it?
08.05.2020 14:01 # 15
I don't think it will have anything to do with the rim
08.05.2020 14:01 # 16
beddri
The problem was in the hydraulic pump, the original was 600 TL.
08.05.2020 14:01 # 17
HakanGokdemir
Get well Bedri, I'm glad the problem is ...
08.05.2020 14:01 # 18
beddri
thank you
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
