click in the front row
08.05.2020 17:54 # 1
koray
friends, I have 206 xt 1.6 1.6 car, even when the car is going on the road, click the front wheels.
08.05.2020 17:54 # 2
qqyyxx
Today, I changed the entire front for 307 min stony roads, as there was a feeling of shaking and space on the steering wheel. I renewed the problem on both sides: swing, ball joint, tie rod, tie rod head, but the problem was not solved, but the front part was tired because of the age and km. no sound anymore. My vehicle was in 2007 model 73 thousand. it was renewed for the first time. this is one of the bars that I counted, probably the one that caused you to click. Of course it can be z rotta. if you can, it is better to renew it completely.
08.05.2020 17:54 # 3
kivanc
I advise you to look at the rods that I used 206 for many years ..
08.05.2020 17:54 # 4
samet206
while turning the steering wheel, a squeak-like sound is made from swings.
08.05.2020 17:54 # 5
kuscu38
If he is doing it while turning the steering wheel and the steering is forced first and then suddenly, the ammunition can be from the top chock balls, if the vehicle is flat, look at them.
08.05.2020 17:54 # 6
koray
There is no normal noise when turning the steering wheel, but it growls on lightly crushed roads. s will be taken, ball joint, tie rod, tie rod head change. I write the results, respect.
