click from running at idle
08.05.2020 16:09 # 1
Sparco54
While the vehicle is running at idle, one click is coming, and when the clutch is pressed, this sound is cut off. What is the source?
08.05.2020 16:09 # 2
[QUOTE = Sparco54] one click while the vehicle is running at idle, and when the clutch is pressed, what is the source of this sound and if I want to troubleshoot any problems, what would it cost if the vehicle 106 is quicksilver [/ QUOTE]
Do you feel vibration on your foot when you put your foot on the clutch pedal or press it lightly?
08.05.2020 16:09 # 3
aksungur19
I had the same problem with my teacher. I had the clutch removed. we saw that the balls were scattered. clutch set xrnin 230TL + balls and seals between 50-60TL + & nbsp; workmanship (I took care of 100TL plus food from my friend) :))
