CLEARING DOES NOT WORK I think I HAVE A SHORT CIRCUIT.
08.05.2020 19:35 # 1
MusTy57
Friends, the dust had escaped into the cigarette lighter the other day. A spark sparked. Looking at the fuses looks solid. When I looked at my mechanic in such a way, I think he said cursory solid fuses or something.
My car 2001 Model Peugeot XT 1.6
What kind of problem might it have been, guys?
08.05.2020 19:35 # 2
xmen
Sir, I had put a needle in my previous vehicle, it didn't work.
08.05.2020 19:35 # 3
MusTy57
I couldn't find the insurance of that. Does anyone know who knows how many insurance is there? Let me give you if necessary, what is it?
08.05.2020 19:35 # 4
MusTy57
Meanwhile the Vehicle
2001 Gasoline 1.6 206 XT I do not know how many hp is not on the license :)
08.05.2020 19:35 # 5
talip206
20 amps, 22 amps from the fuses in the vehicle
http://www.ekilavuz.com/kilavuz/1195f648aedfbb7f/34/peugeot/206-2/binek-otomobil
08.05.2020 19:35 # 6
MusTy57
Thank you very much, teacher, I'll try it right away.
by the way, are you sure this 206 xt 2001 `s?
08.05.2020 19:35 # 7
hakao
I also have this problem 2001 206 1.6 xt but the ceiling lamp or something is working. Is it possible to have insurance or is it something else?
08.05.2020 19:35 # 8
MusTy57
I did not notice an evening that did not work except lighters and torpedo lighting. ceiling or something works. musty57 2016-01-04 22:29:55
08.05.2020 19:35 # 9
hakao
I did not worry about me, I did not worry about it, when I wrote it, I said that I would write it on the license. How many horsepower it is in kw or engine type.
08.05.2020 19:35 # 10
MusTy57
it doesn't write how many kw is in my license.
but the last mechanical master said it was 8 valves, and his first registration should have been 90 hp on 07.09.2000 mine.
08.05.2020 19:35 # 11
talip206
[QUOTE = MusTy57] thank you very much my teacher, i will try it right away.
Sir, I'm not sure for sure, but there are guides according to the engine code in the link I provided. There are 3 guides but I need 20 amps
08.05.2020 19:35 # 12
hakao
For 90 years, mine is like yours with 16 valves 2000 outputs
08.05.2020 19:35 # 13
red 206
First of all my master mrb click sound looks like frightened you :)
(you don't need to be afraid, he throws the most insurance)
If the lighter of the lighter after the click sound works smoothly, there was no problem.
you only short-circuited the + and- poles inside the cigarette lighter that the snap came out of it and did not blow the fuse because the short circuit did not reach up to 20 amps, so nothing happened to your car.
The cigarette lighter socket in the vehicles has + and - ends, the wire inside the lighter is a single wire. disconnects.
Think like a ufo when the wire (resistance) inside the glass is given to both ends 220, the wire becomes hot and reddened.
08.05.2020 19:35 # 14
MusTy57
[QUOTE = red 206] my master firstly mrb click sound looks like frightened you :)
Thank you very much, my teacher.
The reason why he got the icimo draw is that I can't find his insurance. The worst was that the master could not find it: / The insurance above was not good. I don't know how to do it. It takes a lot of effort to get out of the way.
08.05.2020 19:35 # 15
MusTy57
I found the solution of the problem with friends, with the help of friends and trial and error. Cakmaklil had not been working for 2 months.
I changed the insurance two months ago because the insurance exploded, but instead of 15, I put 10. First, I put 20 instead of 10, it didn't work again. Then I looked at the insurance 2 months before I was 15 years old. I played 15 and worked. The ceiling light was on when it was 10. When they were 15, they both worked. I offer my gratitude to the friends who are trying to help the place of insurance. Thanks...
08.05.2020 19:35 # 16
hakao
I also take the insurance insurance numbered 22, I buy 15 tomorrow, but I do not stop working if I do not use it. I'm glad your problem is solved.
08.05.2020 19:35 # 17
red 206
There is no reason that the fuse of the fuse does not work if the amperage is low.
08.05.2020 19:35 # 18
ssakyel
Get well, my teacher says it's time to quit smoking. LOL
08.05.2020 19:35 # 19
MusTy57
[QUOTE = ssakyel] Get well, my teacher says it's time to quit smoking, I think the tool is an assessment LOL
cozdum hocam cigarettes last speed continues
Apart from that, I wanted to use navigation or something. The solution was super. Otherwise, I already have my cigarette in the car :)
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
