cleaning the vehicle engine ...
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 15:57 # 1
darknes0808
I decided to clean the pug 106 quick engine of my car. According to my research, the most correct method is to wipe all parts with a damp cloth first, then pass with a diesel cloth and rinse with a dry cloth. What do you say? =)
08.05.2020 15:57 # 2
mimitt
soften the dirt with oil removers, then brush it with a teapot or something like it, break the hot water and pour it to the places where there is a lot of oil (take care of the electronic circuit). It will be better if you take it from the polishers and apply it to the engine, anti-static products will delay the dusting, do not retain dirt immediately, wd40 and similar products will lubricate, which causes the motun to get dirty quickly.
08.05.2020 15:57 # 3
buddy search the forum on this topic there are different cleaning methods available
08.05.2020 15:57 # 4
ByHack
I think don't touch water soap. 2 weeks ago I took the car for maintenance there on the recommendation of the lightning industry site in Ankara, on the recommendation that there is a peugeot peugeot. First, they extract the dust of the engine with compressed air. Then there is a cleaning spray, pouring a can of spray onto the engine. how much oil, dirt, sediment, if any, of this cleaning spray flows down. They're reworking it with compressed air last. and eventually your vehicle's engine becomes even brighter than it left the factory. Believe me I was very surprised and amazed when I saw it. I would definitely recommend. I think they also sell it on the internet. press the forehead spray, if there is a tire or something nearby, you can take care of it by taking advantage of its air gun ...
08.05.2020 15:57 # 5
Long Beach
never direct pressurized water directly to the engine, or even protect the engine from water (electrical-electronic parts). If the engine is oily (upper cover gasket around, timing belt circumference, transmission motor assembly), clean the job by the method specified by ByHack and then (after making 100-200 km road) check the places I mentioned above if the lubrication is still happening remove it in time.
As I mentioned in my signature, "tamper if it works;)"
08.05.2020 15:57 # 6
toga406
If the slogan is working well, I agree with the tamper
08.05.2020 15:57 # 7
sercinho
[QUOTE = ByHack] I don't think water touch soap. 2 weeks ago I took the car for maintenance there on the recommendation of the lightning industry site in Ankara, on the recommendation that there is a peugeot peugeot. First, they extract the dust of the engine with compressed air. Then there is a cleaning spray, pouring a can of spray onto the engine. how much oil, dirt, sediment, if any, of this cleaning spray flows down. They're reworking it with compressed air last. and eventually your vehicle's engine becomes even brighter than it left the factory. Believe me I was very surprised and amazed when I saw it. I would definitely recommend. I think they also sell it on the internet. press the forehead spray, if there is a tire or something nearby, you can take care of it by taking advantage of its air gun ... [/ QUOTE]
I wonder how much you can pay for your room.
08.05.2020 15:57 # 8
toga406
Even if there is not a lot of money, I will make it from Ankara.
