Cleaning Headlight With Toothpaste
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:57 # 1
Burak
When I was browsing the sites I saw it by chance, I wanted to share it like there is a difference but what do you think would work :)?
[TUBE] http://youtu.be/es_wad2uul A [/ TUBE]
[TUBE] http://youtu.be/h4ffx5epımk [/ TUBE]
08.05.2020 17:57 # 2
yenice
toothpaste already contains marble as abrasive :) but it is necessary to try how effective it is on the headlight :)
08.05.2020 17:57 # 3
Alicilik
[QUOTE = yenice] toothpaste already contains marble as abrasive :) I think it is certain that it will clean. but it is necessary to try how effective it is on the headlight :)
what's up marble: D
the enamel structure of the tooth is a hard layer, and what we eat affects over time. It is CaCO3, which we call calcite, which clears this best. CaCO3 can be found in many different forms in nature. Ramadan is the biggest example of marble that a friend says. It reacts very quickly with acid and manifests itself.
Not every marble is the same calcite. CAlcite is divided into dozens of branches. The most important factor in toothpaste is the theory that we call hardness in science. The substance we call CAlcite can have very different hardnesses, and the enamel has a hardness of about 4 percent. If you use calcite with a hardness above 5, your tooth will be like a school board. Therefore, calcite should be used in the hardness closest to the tooth.
The hardness of the glass is 5 We use the glass as a divider in laboratory lessons and use it to determine the hardness of the stones. If a substance draws glass, it definitely does not have a hardness higher than 5, it is below 5 if it is just walking.
It is a nice application to clean my CA. But as I said, the logic in the cake is also hardness, and the cake is produced according to the hardness of the varnish on the paint. Better results can be obtained with pastes produced according to the glass.
08.05.2020 17:57 # 4
Alicilik
[QUOTE = 307bursa] Ali, we can briefly say that it will not work well:)))))) [/ QUOTE]
Brother, why will there be a problem? LOLLOL
08.05.2020 17:57 # 5
kuscu38
Brother, what do you call this headlight polish, do we use from outside the headlight?
08.05.2020 17:57 # 6
Alicilik
[QUOTE = kuscu38] brother, what do you call this headlight polish outside the headlight? [/ QUOTE]
The outer surface of the headlight is abraded or structurally degraded by the effect of sun, washing and chemicals used.
Unlike polish, the cake is used first. The cake gets the opacity of the surface. You provide a brighter appearance with the polish applied to Üzeirne. So.
There will be a difference when a thick cake is thrown and polished to a medium-sized shadow according to the scratch condition of the glass.
08.05.2020 17:57 # 7
kuscu38
Thank you, teacher.
08.05.2020 17:57 # 8
Alicilik
Thank you, my efenim is beautiful as we share information. :))
08.05.2020 17:57 # 9
Burak
I admire the general culture of the forehead.
08.05.2020 17:57 # 10
tigerland
There are special cleaning polishes for the headlight. but I never used it because I always changed the headlight: D
I think if you want to clean the headlight, try it.
08.05.2020 17:57 # 11
samet206
It has nothing to do with toothpaste or something. I have not tried to make my old eye at home for an hour, it has nothing to do with the images that are told and revealed.
08.05.2020 17:57 # 12
candanxyz
Pull out the 1500 g sandpaper then say to the auto painter, say the cake wax and the number ten with the machine
08.05.2020 17:57 # 13
gkhn08
I think it will be better than the previous one, but in fact, if we think logically, the CIF used for kitchen cleaning will be even more effective. I was unable to get the data because my DVD was over-drawn at the time. It was also very important. I tried to clean with the thing like that residue inside the pair eroded the scratched part of the dvd, it caused the deep scratches to disappear, but then I put the data on the computer without any problems from the inside of the car headlight.
08.05.2020 17:57 # 14
tongucuk
headlight outer surface cleaning is possible with toothpaste and it is successful but it has to be done patiently and carefully with my eyes.
The application is as follows: When the fluoride toothpaste was done with me, the signal was used. You apply it to the surface of the headlight like creams and wait for 10 minutes. You attach a new tip to the polishing machine and pass it with circular movements after 10 minutes. keep wiping with hot water you are doing this application for 40 minutes for a headlight, the result is very very good compared to the past
Note: this process is successful but there are products that are produced to clean the headlight and if these products are cleaned in a shorter time, I recommend using the toothpaste method.
08.05.2020 17:57 # 15
brkhkn
As it is a GENERAL SUBJECT, I HORTAL THEM AND I SHARE INFORMATION :)
PROVIDE THESE 3 THINGS;
1) 4 pieces of sandpaper
2) WATER IN THE CAMSYL BOX
3) CAKE AND POLISH
Is ABRADE; 800 ', 1,000'
1.500 and 2.000. (THE NUMBER OF DRAWINGS ARE DRAWING DRAWING.)
TIGHTEN THE WATER IN THE CAMSIL SPRAY.
SAND ON THE WET FLOOR WITH 800 GRINDERS.
THEN TIGHT TIGHT AGAIN AND SANDING IT WITH 800 GRINDERS. (MAKE 15 TIMES)
DO THE SAME PROCESS IN THE ORDER OF ITS WITH 1,000, 1,500 AND 2,000 GRINDERS. (15 TIMES)
AFTER ALL THE PROCESS IS FINISHED, FIRST PASTE THE PASTRY, AND THEN PULL IT WITH COTTON.
OUT ...
THE PROCESS IS VERY EASY. SIZES FIRST 800 GRINDERS. DO NOT FEAR. CONTINUE ABICIM. IT WILL STAND WITHOUT SCRATCH BUT THE MATERIAL WHEN THE 2,000 STAPER IS ADDED. You can install and look through the intermediate cloth.
HELE MAKES THE LASTEST CAKE AND THEN LIKES ZERO THROUGH THE POLISH.
