ciyk sound 307 xt premium
08.05.2020 15:21 # 1
muhammed43040
My friends problem is that when I lift my car a little hard or when I pull my foot out of the gas while going in 2nd gear on the road, there is a voice that comes out from the bottom. muhammed43040 2011-05-01 12:36:40
08.05.2020 15:21 # 2
Muhammet CAKIR
I have to see the bro, my brother, I couldn't understand exactly where it came from.
08.05.2020 15:21 # 3
Ozgur
THE SAME SOUND IS WITH ME.
EGR VALVE REPLACEMENT REPLACEMENT REQUIRED NO SERVICE.
I still use it.
08.05.2020 15:21 # 4
only_younus
can be exhaust flange
08.05.2020 15:21 # 5
sace
I have had exhaust flange too
08.05.2020 15:21 # 6
oguz6578
the same is in me too bro :))) what exactly do you call the exhaust flange ....
08.05.2020 15:21 # 7
oguz6578
There are those who say that the sound is heard from outside, the sound is coming from the middle of the exhaust.
08.05.2020 15:21 # 8
only_younus
Under the car;)
joking aside, I didn't remember the exact place, but I think it was where the exhaust pipe came out of the engine, 15 cm behind the front wheels in the middle
What is called a flange is a ring with a diameter of about 6 cm and a thickness of 0.5 cm is not very expensive.
By the way, I am looking for that sound after changing the flange, if it has no harm (more experienced friends answer) it is a habit :)
08.05.2020 15:21 # 9
oguz6578
:)))) There are those who call it grease, let's try ...
08.05.2020 15:21 # 10
[QUOTE = oguz6578] :)))) there are those who call it grease smear. Let's try it ... [/ QUOTE]
Did your problem resolve or have you tried?
In such places, virgin grease is better than normal grease.
08.05.2020 15:21 # 11
oguz6578
I haven't tried vala but let me see today :)))
08.05.2020 15:21 # 12
[QUOTE = oguz6578] I haven't tried vala but let me see it today:))) [/ QUOTE]
I am still following the subject you are doing and I expect you to try and write.
08.05.2020 15:21 # 13
oguz6578
Nowadays, LPG fln has been dealing.
08.05.2020 15:21 # 14
Ozgur
I said the exhaust flange to the service, but they insistently called me the exhaust valve.
I did not change the exhaust flange.
08.05.2020 15:21 # 15
muhammed43040
construction exhaust flash let me see if we drive grease or something
08.05.2020 15:21 # 16
muhammed43040
In another problem, I have to turn off the signal arm automatically, it is not normal, is it okay?
08.05.2020 15:21 # 17
BUBU
I have the same change your exhaust flange in the service 10 TL
08.05.2020 15:21 # 18
oguz6578
I said let me look at 4 noon at noon but I bent down like this, but in vain the car is close to the ground, I see a few pieces under it hard :)))))
08.05.2020 15:21 # 19
[QUOTE = oguz6578] at 4 noon I said let me look at the fln, I bent down like this, but in vain the car is close to the ground, I see a few pieces under it :))))) [/ QUOTE]
I've seen the lowered form of the 307 SW many times, but I wondered about yours. If you see the pictures of your vehicle on the part of the users?
08.05.2020 15:21 # 20
sedat23
exostan my brother was doing it in my old 307 there used to be something like bow there is no problem doing it take it to an exhauster
Page : / 2
