CIYK CIYK SOUND
08.05.2020 15:21 # 1
BUBU
I HAVE FRIENDS WITH ITS 2004 307 WHAT CAN I HAVE FRIENDS THAT HAVE BEEN THE SAME PROBLEMS?
08.05.2020 15:21 # 2
[QUOTE = BUBU] THERE ARE FRIENDS IN 2004 I HAVE FRIENDS WHICH HAVE THE SAME PROBLEMS, WHICH MAY BE A SINGLE VOICE FROM THE SKY DIGITAL LIGHT WHEN CHANGING THE GEAR IN THE LATEST VEHICLE? [/ QUOTE]
You get a lot of trouble per listening. You should turn up the music more. Sırıtma
08.05.2020 15:21 # 3
goktug
A brother to look at the gearbox oil.
08.05.2020 15:21 # 4
azdek
Hodja may not speak precisely, the clutch may be finished, I have a 2005 model, even it is time to change it.
08.05.2020 15:21 # 5
BUBU
By the way, I have been warned that the big letter is written by siye. What does it mean?
08.05.2020 15:21 # 6
BUBU
walla they called me this exhaust thing but i don't understand
08.05.2020 15:21 # 7
[QUOTE = BUBU] By the way, I have been warned that the big letter is written by the sze .. msg is exactly - all the big articles mean other things? what does it mean that kutfen siye directors do not happen so much .. rule is not so much pesss [/ QUOTE]
Wherever you wrote, you should have answered. I prefer to make the warnings via private message. I am trying not to make any warnings in the forum. Besides, there is a topical subject about the subject you said to give up, which has been said to be open and uncomfortable in the past days.
Here you are: http://forum.peugeotturkey.com/forum_posts.asp?TID=14394&title=byk-yaz-fontlarna-dikkat
In addition, the topic you said to give up is clearly stated (twice) among the forum rules.
Your reaction to the rule may be of course. You can also say this in a topical destination, but as such, our rules are now ready. Thank you for your compliance.
08.05.2020 15:21 # 8
[QUOTE = koliva] [QUOTE = BUBU] By the way, I was warned that the upper case letter was written by the mage. what does it mean that kutfen siye directors do not happen so much .. rule is not so much pesss [/ QUOTE]
BUBU My Brother It Is Not Correct For You To Respond Such A Reaction ... There Are Definitely Everywhere There Are Some Rules
the albaydemirc 2011-04-30 12:36:49
08.05.2020 15:21 # 9
sace
If it is called exhaust, try it like this, give some gas while going in 2nd gear, then take your foot off the gas, so shake the car a little bit. If you hear the same sound, change the exhaust flange, no sound will be left.
08.05.2020 15:21 # 10
206_arda_+
[QUOTE = hakangumus] [QUOTE = BUBU] FRIENDS HAVE 2004 307 IN THE VEHICLE WHAT CAN I HAVE A SINGLE PROBLEMS WHICH HAVE A SINGLE PROBLEM OF THE LIGHT VOICE IN THE VEHICLE? [/ QUOTE]
You get a lot of trouble per listening. You should turn up the music more. Sırıtma [/ QUOTE]
Hahahahahaha =))) I had 2001 206 gti. folks, I thought that I had a sound system built to be crocheted, whereas I had it installed so that I could not hear the sounds coming from the car =)).
08.05.2020 15:21 # 11
BUBU
yes yes from exhaust flans
08.05.2020 15:21 # 12
BUBU
they said the exhaust flans right
08.05.2020 15:21 # 13
only_younus
Something you can replace with very cheap cost, I have done the exhaust flange for 30 TL I think
