Citroen c3 Cruise Control
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 16:49 # 1
losabere
Hello, good day
2007 model 1.6 Hdi 92 bg sx I installed the speed stabilization and limiting arm smoothly on my vehicle
I have the lexia 3 program used by the service and the original equipment there are 4 options in the menus, speed stabilization and limiting, overspeed warning, speed stabilization and student tool, speed stabilization and overspeed alert no matter which one I choose, speed stabilization is not activated. Cruise control is imposible on 1st, 2nd and 3rd gears, this warning does not appear in 4th and 5th gear, but the -------s next to the sign flash for 7 seconds. Although I ask you to have a Peugeot forum, the technical infrastructures of our vehicles are the same, if you have the same situation, there is no problem in my experiment since I have the device in my hand.
08.05.2020 16:49 # 2
[QUOTE = losabere] Hello, good day
2007 model 1.6 Hdi 92 bg sx I installed the cruise control and the limiting arm without any problems
I have the lexia 3 program used by the service and the original equipment there are 4 options in the menus, cruise control and limiting , over-speed alert, speed stabilization and student tool, speed-fix and over-speed alert, whichever I choose, speed stabilization is not active. Cruise control is imposible on 1st, 2nd and 3rd gears, this warning does not appear in 4th and 5th gear, but the -------s next to the sign flash for 7 seconds. Although I ask you to have a Peugeot forum, the technical infrastructures of our vehicles are the same, and if you have the same situation, there is no problem in my experiment because I have a device. >
Hello,
Did you check your car's brake release before making the necessary adjustments from Lexia, didn't you? You should be able to set the menus in some way, but first you need to check the suitability of the brake pole.
08.05.2020 16:49 # 3
losabere
There are two cables on the brake pedal, should it be 4? How can I get the necessary cables?
08.05.2020 16:49 # 4
[QUOTE = losabere] There are two cables entering the brake pedal, should it be 4? How can I get the necessary cables? [/ QUOTE]
There are two types of systems. In the first system, there are two different pulleys on the brake pedal and two cables enter these two sensors. One of these sensors is for brake lights, the other is for cruise control. I think this system is mostly in older models. In the second system, there is one brake pole on the brake pedal and 4 cables enter this musure. Two of them are brake lights, two of them are for cruise control.
I think your situation fits the second system. So you have one sensor and you have 4 cable entry points. Currently, only two are full and these are for the brake lights. As I said, I have to stretch out and say that your job is a bit long. Once it is certain, your cruise control system will not operate until the cable is empty for the cruise control in that manager. In our forum, we accomplished this with our friend from Istanbul. We were able to introduce the cruise control by drawing extra cables from the ECU to the brake coupler in the Peugeot 307 SW. However, you need to find the electrical schemes suitable for your vehicle from Sedre. Obviously the risk side of this business is overpowering. If you say I will / will do this, we are happy to convey what we know and help.
08.05.2020 16:49 # 5
losabere
I checked my car according to citroenden number, the technical infrastructure of the vehicle other than the speed stabilizer arm was said to be suitable for speed stabilization. When I look at it, there is no problem in braking or brake lights, I think it may be from the brake sensor. > 2012-05-29 14:55:09
08.05.2020 16:49 # 6
[QUOTE = losabere] I had my car checked according to citroenden number, the technical infrastructure of the vehicle other than the speed stabilizer arm was said to be suitable for speed stabilization. It looks like, but when I look at it from the outside, I think there is no problem with braking or brake lights, I think it may be from the brake sensor. br> They cannot see the cable connections when they check by number. I guess they're just looking at whether the arm is suitable for all arms.
You take a photo of where the brake disc is located and put it here. In this way, we proceed more firmly.
08.05.2020 16:49 # 7
istanbullu_3886
I think the foss brother is in service and the brains are not in my car, but we did it thanks to my brother koliva and it works smoothly
08.05.2020 16:49 # 8
losabere
Speed stabilization and Speed limitation 2006 1.6 16v automatic actively working on my friends, due to the reason why it did not work in my 2007 1.6 hdi 92 hp vehicle, two of the customers on the brake were inserted and two of the cables were completed in the diesel vehicle.
08.05.2020 16:49 # 9
[QUOTE = losabere] Speed stabilization and Speed limiting 2006 1.6 16v is working actively on my car, friends, 2007 1.6 hdi 92 bg did not work on my car, the customer on the brake was 4 times in two minutes after the two cables entered the customer on the brake and completed the operation, two more in the diesel cable must be pulled. [/ QUOTE]
Okay, so we said it "Smile" The brake coupler connections in your 2006 model vehicle tau am. The other is missing. It is not a difficult process to pull, but it is necessary to know where to pull the cable, making sure that it requires mastery. Reviews
08.05.2020 16:49 # 10
Ozgur
I am using it on my 2006 model diesel 206 without any problems. Özgür 2012-06-02 12:27:12
08.05.2020 16:49 # 11
losabere
[QUOTE = Özgür] I use it on my 2006 model diesel 206 without any problem. [/ QUOTE]
BRAKE PEDAL INTO YOUR PEDAL
15.09.2020 02:57 # 12
italyano18
My master, there are 2 cables in the brake sensor, the other two can you describe where we will pull, whether you share a diagram or a photo is easy. I have researched where the cables go, but no one says.
