Citroen c elysee
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
17.07.2021 10:13 # 1
umitdagli
Hi Aleyküm Friends,
I have a Citroen C elysee 2014 model 120k vehicle,
2 I have problems, both are related to each other.
1. While changing gear, the gas waits for 1-2 seconds and then drops,
This problem is common but sometimes it does not happen.
2. problem cruise control is not working 3 dots flashing.
2. problem happens when there is problem 1,
1. If there is no problem, then there is no problem.
Master said injector, but I could not understand what is the relevance of the speed stabilizer.
I would appreciate if anyone who has a similar problem can help, I have the vehicle regularly serviced.
31.07.2021 21:27 # 2
umitdagli
I found the answer to the question and Solved it
master said injector, but I searched without looking.
In the video below, like 307 model, our 301-Citroen cellysee also has a clutch switch.
When you press the pressure, it informs Ecu, mine is oxidized. It didn't work because of that,
The throttle in the cruise control and gear change was caused by this.
I took out the clutch switch, I opened it, I cleaned it, I sanded it, and it worked.
My problem is solved, Maybe other friends will need it.
https ://www.youtube.com/watch?v=r5X1jgv6lNU
