Citroen c elysee 2014 exclusive
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:29 # 1
umitdagli
Hello, My new car Citroen c elysee 2014 exclusive model,
The problem with my vehicle is that the Information screen does not work, I noticed that the vehicle that bought zero in the person I bought did not work a few months ago,
Mode: I checked the sleep mode, the yellow chic flashes at the back, but the screen is not displayed, Is the screen distorted. or is there a problem elsewhere?
I would be glad if you share your knowledge ..
Good forums.
08.05.2020 21:29 # 2
GokhaN
Hi
the screen is probably broken
08.05.2020 21:29 # 3
umitdagli
Thanks for information.
Do I have the opportunity to test the toughness of the screen without buying a screen?
08.05.2020 21:29 # 4
you will have to try on another vehicle.
08.05.2020 21:29 # 5
umitdagli
Thank you for the information you provided, I went to the service this day, the service disassembled the battery terminal, worked and worked, In the evening until I came home and got back to the car one hour later ..
Suan does not work again. The problem is not on the screen or tape. The problem is that I think that there is a lack of contact in one place, I looked at the brain sockets, dusty from there, I suspect from there, If the sockets are removed and cleaned (I do not know what to clean with).
08.05.2020 21:29 # 6
umitdagli
The vehicle was used before in the village environment on dusty roads. When I remove the brain box, it proves in the dust here. I think the dust that entered between the socket seems to be contactless.
Will the W 40 do this job? Is there any situation that I should be careful about when the battery is removed from the pole cap?
08.05.2020 21:29 # 7
Orcun.Dmr
Wd40, but also with lining spray, you can clean the socket when the battery terminals are removed.
08.05.2020 21:29 # 8
umitdagli
Finally I want to ask something, is there a 6 pin screen connection scheme? My goal is to measure the voltage coming from here .. 2 pins of the pins are 12 volts + - the other 2 pins are empty, 2 pins canbus 4.6 volts if these values are correct, the screen is probably broken, there is no other communication that I do not know :)
the umitdagl 2020-03-15 11:33:23
08.05.2020 21:29 # 9
fatihcetinn99
The screen is out of order due to broken iron ??
08.05.2020 21:29 # 10
umitdagli
Hello, First of all, thanks to Gökan Bey who is the Manager, He made the first diagnosis because the screen was defective,
We did not doubt that the screen came together, we researched, measured the electric current, the screen turned out to be defective.
2 days ago, I bought a 2017 model citroen vehicle from the front frame, tape, screen inside of a friend on the internet, I just did the screen assembly.
I would like to thank all interested friends ..
NOTE: I can get the Citroen C elysee Tape / Front Panel Frame that I have received in full, at a very affordable price ...
the umitdagl 2020-03-20 10:04:15
08.05.2020 21:29 # 11
Orcun.Dmr
[QUOTE = umitdagli] Hello, Thanks first to Gökan Bey who is the Manager, He made the first diagnosis because the screen was faulty,
NOTE: I can get Citroen C elysee Tape / Front Panel Frame at very affordable price, which I have bought Cople to who needs it ...
Hodja, from which site did you download the photo? I try it too, but it always uploads as a link and the photo is not directly visible.
08.05.2020 21:29 # 12
umitdagli
I used the bottom url after uploading a picture from the quicklink site ..
08.05.2020 21:29 # 13
get past it.
08.05.2020 21:29 # 14
umitdagli
Thank you Wink
