Cit cit sound from the 301 engine (with video)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:14 # 1
Tutsak09
[TUBE] _gmhzxbztvm [/ TUBE]
This sound has been coming from the vehicle for more than 1 month and I feel like it has started to increase gradually, sometimes it is interrupted, sometimes it does not come after making a change.
08.05.2020 21:14 # 2
dijital elektirik
hi as if sibobs are hitting but i think you better look at the master
08.05.2020 21:14 # 3
Tutsak09
Does anyone know about other subject?
08.05.2020 21:14 # 4
samet2461
As if the syringe comes from there, 3 things come to mind in this case.
- either exhaust or manifold leak
- Injector needle sound
Compression leakage from under the injector
08.05.2020 21:14 # 5
pusutr
Compressor leak. the washers must be worn out of the washers. stamps are very cheap and they want 150 200 TL for labor. Replace the scales of the 4 injectors while looking ready.
08.05.2020 21:14 # 6
Tutsak09
[QUOTE = pusutr] Compressor leak. the washers must be worn out of the washers. stamps are very cheap and they want 150 200 TL for labor. Replace the scales of the 4 injectors while looking ready. Or if I don't change them, are there 1-2 months bigger problems? Is it an emergency?
08.05.2020 21:14 # 7
pusutr
Compressor leakage is related to the traction of the vehicle. Traction will drop as pressure leakage will occur inside the engine. And since there will be a rich mixture in the engine, dense smoke will come out of the exhaust.
206's air conditioner is already weak. I would make it empty every 2 years. But a good master has to do this. Cooling was then acceptable.
08.05.2020 21:14 # 8
burakkurekci
Yes, it came to me like that.
