Cigarette lighter with the ignition off
08.05.2020 21:08 # 1
lilokan
Hello friends. I applied a tablet to the vehicle. I want to constantly give power from the tablet. When the ignition is off, it cuts off electricity as it is. How can we get electricity from this crank when the ignition is off? I want the tablet to charge constantly. Also, is there any harm?
08.05.2020 21:08 # 2
Karacocuk24
[QUOTE = lilokan] friends hello. I applied a tablet to the vehicle. I want to constantly give power from the tablet. When the ignition is off, it cuts off electricity as it is. How can we get electricity from this crank when the ignition is off? I want the tablet to charge constantly. Also, is there any harm? [/ QUOTE] my car is powering off with the ignition off, but it is not a healthy operation, I think you will give up this unexpected battery or you will encounter similar problems. If you want direct electricity, there is a 12 V incoming cable to the cables behind the tape and you can find and apply it.
08.05.2020 21:08 # 3
Kysr038
The cable behind the tape can also turn eco mode on and off after 30 minutes.
I wonder if it is possible to connect a Powerbank. When you start the vehicle, the powerbank will be filled and will continue feeding the tablet with the ignition off. It would be nice if it could be done.
In this way, you do not have the possibility of running out of battery while lying down.
08.05.2020 21:08 # 4
OguzhanKucuk61
You must remove the battery of the tablet you are using, if it is going to be in the vehicle all the time. There is a risk of the battery flaring, explosion inside. When leaving the tablet suitable for home and office use in the car, it can cause problems in the battery.
Doing what you want can also run out of your battery.
There are application videos on YouTube. the battery will be removed and the energy will be taken from the contact. When you turn the key one step, the tablet will energize and turn on. the tablet will turn off when you switch off the ignition. I think this is the healthiest and ideal for use in the vehicle.
08.05.2020 21:08 # 5
lilokan
Thanks for the reply. Yes, the tape cuts the electricity after a while. In fact, I want to insert the battery of the tape that makes sense. In this way, the tablet is open as soon as it gives electricity. But when the battery is on, the tablet first opens after the battery has reached a certain energy. it takes time. I signify Sivas. Unfortunately, they cannot manage to insert the battery of the tablet directly with electricity. I would appreciate if you share a barrier that can do it. Let me send the tablet directly. Type the battery will be a problem battery
08.05.2020 21:08 # 6
lilokan
[QUOTE = OguzhanKucuk61] you need to remove the battery of the tablet you are using, if it will stop in the vehicle. There is a risk of the battery flaring, explosion inside. When leaving the tablet suitable for home and office use in the car, it can cause problems in the battery.
Hodja, do you know that there is a barrier that you can insert the battery of the tablet and operate it directly with electricity?
08.05.2020 21:08 # 7
OguzhanKucuk61
[QUOTE = lilokan] [QUOTE = OguzhanKucuk61] If you need to remove the battery of the tablet you are using, it will always stop in the vehicle. There is a risk of the battery flaring, explosion inside. When leaving the tablet suitable for home and office use in the car, it can cause problems in the battery.
I cannot recommend any master in Sivas. But not necessarily an auto electrician. A telephonist or electrician who understands the job can do what we mentioned. It can disassemble the battery and make the necessary wiring from the plus minus output, making it possible for the auto electrician to get energy from the Contact.
08.05.2020 21:08 # 8
AhmetSehzade
[QUOTE = lilokan] friends for the reply. Yes, the tape cuts the electricity after a while. In fact, I want to insert the battery of the tape that makes sense. In this way, the tablet is open as soon as it gives electricity. But when the battery is on, the tablet first opens after the battery has reached a certain energy. it takes time. I signify Sivas. Unfortunately, they cannot manage to insert the battery of the tablet directly with electricity. I would appreciate if you share a barrier that can do it. Let me send the tablet directly. Type the battery will be a problem battery [/ QUOTE]
I live in Sivas, I was able to find neither motor nor electricity nor sub-team master There is no master in Sivas who really does his job voluntarily.
08.05.2020 21:08 # 9
lilokan
[QUOTE = OguzhanKucuk61] [QUOTE = lilokan] [QUOTE = OguzhanKucuk61] you need to remove the battery of the tablet you are using, if it will stay in the vehicle all the time. There is a risk of the battery flaring, explosion inside. When leaving the tablet suitable for home and office use in the car, it can cause problems in the battery.
Sir, should I send you a tablet that you can recommend?
08.05.2020 21:08 # 10
lilokan
[QUOTE]
You are absolutely right, hodja
08.05.2020 21:08 # 11
AhmetSehzade
[QUOTE = liloan]
[QUOTE]
I will just let you know what's in this place, I will go to Istanbul, and there are beautiful masters.
08.05.2020 21:08 # 12
OguzhanKucuk61
the @lilok
I cannot advise because I have not experienced. There are individuals or individuals making app videos on YouTube. They promote their shops and brands. You can contact them and get help. Or you can send the tablet to our forum members in big cities and get help in this way. Of course if there is a forum member who will tell the masters to wire your tablet. LOL
08.05.2020 21:08 # 13
lilokan
where do we get captured, hodja Big smile
