cigarette lighter cable
08.05.2020 20:16 # 1
hzr206
Good day to everyone ;
There was a problem with my cigarette lighter, I don't have the original cigarette lighter socket, I will necessarily connect one of the universal ones in my car, but there are 3 wires.
I will plug the socket link below
http://www.hepsiburada.com/space-yesil-isikli-universal-komple-cakmak-840917-p-otm840917
hzr206 2017-04-01 19:10:26
08.05.2020 20:16 # 2
Halil5759
You need to check with 12v control pen
08.05.2020 20:16 # 3
hzr206
[QUOTE = Halil5759] You need to check with 12v control pen [/ QUOTE]
12v pens only check if electricity is passing + - how can I distinguish the tip?
08.05.2020 20:16 # 4
ggitaristt
With the avometer, it is also called a measuring instrument + - which tells which. But there is no need to take a small 12V bulb two by two is worth it. The cable remaining when the lamp is on is the lighting. Then burn the parks with the remaining cable, whichever of the other two lights up the lamp. It is the chassis.
there
+ feed
+ lighting
- chassis
There are 3 cables.
08.05.2020 20:16 # 5
hzr206
[QUOTE = ggitaristt] With the avometer, it is also called a measuring instrument + - which one tells you. But there is no need to take a small 12V bulb two by two is worth it. The cable remaining when the lamp is on is the lighting. Then burn the parks with the remaining cable, whichever of the other two lights up the lamp. It is the chassis.
there
+ feed
+ lighting
- chassis
There are 3 cables.
Thanks I got it very well I will try it after I get the lighter.
