chronic fuel pump failure
08.05.2020 19:57 # 1
sfk61
friends I have not seen the subject opened before. I'm new at the forum yet. it doesn't work because it doesn't draw the gasoline when the car is tilted to the left. It was a chronic problem as I know it in 306.
08.05.2020 19:57 # 2
I think if you don't drop it under the quarter tank, there will be no problem with fuel. However, I have never heard of such a thing. Obviously, when the vehicle lies to the left, the gasoline in front of the pump decreases, but it should be very min. Even so, the gasoline in the fuel hoses run the vehicle for a certain period of time.
08.05.2020 19:57 # 3
306COSKUN
FRIENDS PETROL PUMP you are working that AS FOLLOWS UNDERSTAND you IGNITION ENGINE SOUND IS COMING BACK SEAT WHEN YOU TURN ON IF IT WORKS DEMEKTİR.BENZ of ENGINE GO GO is UNDERSTANDING FOR REAR SEAT REMOVE THE FUEL PUMP ON 2 PIECE HOSE HAVE DOORS WITH REMOVE THE SWITCH WILL APPEAR IN THE RE-OPEN GASOLINE IS COMING if TAZİKL in PUMP WITH THE PROBLEM IS NOT. If GEL FUEL PUMP REMOVE THE DISCONNECT MOTOR MOTOR TIRE which ENTER PLACE DEM ALUMINUM A BRACELET HAVE TIME OR BRACELET wrap-spliting and USTA They DO NOT SEE BLEZİG the REMOVE THE INSIDE broken REMOVE PLASTIC OR RING TUBE in HEATING IN THE SAME PLACE hot PUT THE VERY GOOD HANDLE .This happened to me EVENTS 4 TANE 306 THERE IS THE SOLUTION THAT IS THE PROBLEM OF THE 306 S GAS PUMP IS NOTHING ELSE.
08.05.2020 19:57 # 4
Shon2134
selamunalrykum is there anybody who solves the problem of not working when this araö is left
