Choice of 307 tires
08.05.2020 17:47 # 1
cnrars
Friends, I'm going to buy a tire on my vehicle, the ones on it are very old, there are 195x65x15 on it, if I buy 205x65x15 instead, what's the difference, what are the benefits, what's the petlas?
Thanks,
08.05.2020 17:47 # 2
hsnsnl
the base will be wider, the fuel will increase, your grip will increase .. like petlas i rubber, but I get the sound, I would recommend the gasket.
08.05.2020 17:47 # 3
dream
conti cec5 plug walk without looking back ..
08.05.2020 17:47 # 4
cnrars
Well, would it be ridiculous if I bought a winter tire? In the meantime, the prices in winter tires are affordable, cnrars 2013-07-11 14:24:24
08.05.2020 17:47 # 5
Mustafa-almanya
If you use summer with winter tires, the tires become overheated, and there may be a problem on the long road. In addition, using winter tires worn out their profiles quickly.
08.05.2020 17:47 # 6
cnrars
[QUOTE = onurazgin] 205/65/17 senn does not fit the vehicle, km is the handle of the meter, the vehicle becomes cumbersome. You should use tires in the same module. In order to have an idea that the headlight should not exceed 2%;
http://www.lastiknet.com/icerik.asp?inf=25 [/ QUOTE]
Thank you for your answer, but I think 205x65x15, not 17, now there is 195x65x15.
08.05.2020 17:47 # 7
Alicilik
Hello sir,
It is not clear how the weather will be in Ankara. We live all 4 seasons. When you buy tires, your car's load situation plays a role in choosing the performance you want on the roads (road holding-softness-speed).
We always use michelin as a family tradition. A tire brand of the same quality since day one. Whether it is summer or winter, he did not leave it on the road. We use alpine in winter with energy saver or primacy hp in winter. Due to the fp rate, we bought the BFGoodRich tire from the michelin factories to the corsa vehicle. Although Micehlin does not have a softness, it is soft than other cheap tires in its category.
I pay attention to the use of tires and wheels. The powder goes normally on the stony road and I try to turn the steering wheel of the vehicle as it moves. These are important factors. It is also useful to check the tire pressures once a week.
YAS, as I said for the winter event, it is not known when and what happens in Ankara, but in winter, summer and summer are very difficult when we live hard. For this, I wear winter tires when it drops to 10 degrees and below by getting tired of the weather change so that we also use the winter tires on the black rim. The tire breaker damages the edges of the plug. If salt is thrown on the snowy road, clean the tires with water the next day.
It is a model designed for people who have a mild tire climate in 4 seasons or who use the vehicle very rarely. You cannot get an appointment in winter or summer. If you use the vehicle in Ankara, summer is a must in winter and winter is a must. There is no need to risk the 20000tl car with your life for 100-200.
If you come to the dimensions you mentioned, you will not experience any problems, but there will be a slight growth in the outer diameter, which is reflected in your km counter. There is a difference between 65 cheeks of 215 and 65 cheeks of 205.
The effectiveness of your fuel depends on you. Tire is not a factor that increases fuel. Since the expanding base will increase friction, the power produced by the engine will have less impact than the old tire, so you will try to close the gap by pressing more gas. In addition, the friction factor will improve handling.
I saw people who use Petlas who are not satisfied. The sound insulation of the car is low - if the undercarriage and maintenance-free wheels are problematic, the tire pressures are irregular, you cannot be satisfied even if you wear the king tire. Even after that, petlas will cut you off the ground and show od performance according to the condition of the road. We can not say that it does not work very badly.
Conti was also a mediocre brand when it first came out, but over time it had improved itself so sc1 had the aurisde feel obvious, but when the primacy was replaced with hp, the vehicle relaxed. they recommend sc5 very much, if i raise the rim to 18e, i plan to get sc5 in terms of fp (Sportcontact5)
Determine the way you use it and what you expect from the tire. Tires of the car are also important, like human feet.
08.05.2020 17:47 # 8
cnrars
Thank you for taking time and writing for a long time, brother brother, I bought 195x65x15 from the same size on it, bought petlas and June 2013 production, I bought 4 tires for 480 lira,
08.05.2020 17:47 # 9
Alicilik
[QUOTE = cnrars] Bro, brother of brothers, thank you for taking the time and writing for a long time, 195x65x15 so I bought the same size, I bought petlas and June 2013 production, I bought 4 tires for 480 lira,
You're welcome, Hodja.
Good luck and use it without any accident on good days. You shouldn't be surprised by the original. Maybe another 30 TL could be broken. I hope nitrogen has been printed.
08.05.2020 17:47 # 10
individual
205/65/15 would be a wrong choice. Good thing you didn't
Your vehicle would rise unnecessarily off the ground. Therefore, dynamics such as braking and handling would weaken.
08.05.2020 17:47 # 11
error
I suggest you move from 195x65x15 to 205 60 15, not 65.
