Choice of 15 '' wheels
08.05.2020 16:18 # 1
lkr_yldz
friends I'm thinking of buying new tires on my 15 '' gti wheels I bought, but 195 / 50 / 15 and 195 / 55 / 15 I am undecided between what do you think I should do, I do not want to lose comfort and I want it to look visually beautiful
08.05.2020 16:18 # 2
originally whatever the total diameter should be, you should definitely get the braking distance of the vehicle, the mileage you read, the fuel, the traction affects them all.
08.05.2020 16:18 # 3
If the width of the sidewall is 50, it will look nicer, but if you have a pit bump or bad places on the road you are using, you should be careful since the length of the sidewall is short, you will damage the rim and the tire, so if you say there is no broken road, the 50 cheeks will look nicer.
08.05.2020 16:18 # 4
lkr_yldz
[QUOTE = HuseyinTurk] you should definitely get the one that will provide what the total diameter is in the original, the braking distance of the vehicle, the mileage you read, the fuel, the traction affects them all. `` I did not need to change the tires in 65. I did not decide what to do with this rim
08.05.2020 16:18 # 5
lkr_yldz
[QUOTE = 06ilhan06] If the sidewall width is 50, it will look nicer, but if you have a pit bump or bad places on the road you use, you should pay attention, because the sidewall is short, you will damage your rim and tire. the roads of our country are not known, neither good nor bad, I use the car on weekends and do not use hard.
08.05.2020 16:18 # 6
Engin Tepe
I guess there is a change in cap when you make 14 u 15 and 55 in 65.
We also use 50 cheek jetta 1300kg vehicle is very good, there are 45 to 50 differences but I think 50 to 55 is ok. be comfortable.
08.05.2020 16:18 # 7
then you can buy 50 cheeks, it will be cheaper and more flashy, but enter the pits carefully. "Laugh" title = "Laugh" />
08.05.2020 16:18 # 8
we definitely use 195 * 55 * 15 .. reference = cecoli + by_ersin this is the exact size ...
08.05.2020 16:18 # 9
lkr_yldz
I have never seen 206 & & nbsp; using 55 cheeks.
08.05.2020 16:18 # 10
mdincer34
You can be sure that there will be more loss of comfort on 50 cheeks. 55 cheeks are a better choice for me, but 55 cheeks :)
08.05.2020 16:18 # 11
http://www.lastix.com/haberler.asp?nws= 14 & nbsp; my friend look you are calculating from here. The percentage difference should not exceed 3 percent is 60 more ideal, I think you will not lose as much comfort.
08.05.2020 16:18 # 12
lkr_yldz
I found out 55 cheeks hankook brand is good in terms of condition 220 tl says how do you think
08.05.2020 16:18 # 13
mdincer34
Do not rely on the tire, do not take it, even the tire of each vehicle is different. You will buy it. For this reason, go lasssa petlas, if you do not have money, it can be cheap but it will be easy to get out of mind.
08.05.2020 16:18 # 14
lkr_yldz
[QUOTE = HuseyinTurk] http://www.lastix.com/news .asp? nws = 14 & nbsp; my friend look at you from here. I think the percentage difference should not exceed 3 percent, 60 would be more ideal, even I would not lose as a comfort. -1.232% ... it turns out that it is below the limit, but - is it good or bad?
08.05.2020 16:18 # 15
lkr_yldz
[QUOTE = mdincer34] do not rely on the tire to come out and do not take the tire of every vehicle is different. For this reason, go lasssa petlas, if you have no money, it is cheap, but it is easy to get out of mind. I am likely to come out with a tire. I don't want to enter the cheap Chinese goods, I bought the rims, it's on the sidelines
08.05.2020 16:18 # 16
Muhammet CAKIR
I was using 195-50-15, there was no problem. When the Kutahya roads run out of the pits like the cobweb nest, & nbsp; stretch on the cheek & nbsp; don't worry so much don't worry. editDate> 2011-10-30 10:42:39
