Chips installed in diesel and fuel saving ... |
| 08.05.2020 13:56 | # 1 |
taylan43 |
How many kms of your vehicles can you drive with a normal fuel, a tank of fuel? With 206 HDI , 165YTL diesel fuel that I own, I could do 950 km maximum, but it was mixed inside and outside the city and when I pressed a little bit in between ... So do you think it's normal? Because I see ads everywhere, I see the device ads attached to the fuel pump or turbo. I obviously do not want to install a mechanism that I call CHIP and I do not have information about how useful it is and I would be glad if you can help me in this regard. If anyone is using this system in their vehicle, I want to know how it works. Thank you for your answers in advance ...
| 08.05.2020 13:56 | # 2 |
If you asked the question wrong, the thing you say is Chıp is interfering with your brain.
| 08.05.2020 13:56 | # 3 |
taylan43 |
I did not have much information on that issue. Serhat Bey had to say that because of this, but I talked to a company that interfered with the brain and they told me that they sent the code inside the vehicle's brain to Germany and revised and re-code it. But they sell chips under the name of 25% performance and 10% fuel savings, which I have also seen in a few industrial sites, and I don't know how it works and how it works. I have already opened this topic here to find out, but the link to this is for example the product I have given below. There are 100s of products like these, of course, this is just one of them.
| 08.05.2020 13:56 | # 4 |
taylan43 |
I http://www.sahibinden.com/gercek_performans_chip_peugeot_106_206_306_34_hp_benzinwqqaxqq9009969wqqpxqqdisplayite B i've found it. But as I said, I am not absolutely sure.
| 08.05.2020 13:56 | # 5 |
The first is the real thing in the second, the second one is not taken, but you get the + 25 hp or something in the top of the diesel.
| 08.05.2020 13:56 | # 6 |
taylan43 |
So does this have any harm to the vehicle? Do you have any information about that? or is there any barrier you know about?
| 08.05.2020 13:56 | # 7 |
buddy, if you want power increase, cancel chip and floor without thinking ... if there is not much increase in fuel, use it normally
| 08.05.2020 13:56 | # 8 |
taylan43 |
So is there somewhere you can recommend to me?
| 08.05.2020 13:56 | # 9 |
bro |
I said I should be hooking the subject because I am curious too. I have read many places and also had friends who use it. |
| 08.05.2020 13:56 | # 10 |
My friend who wrote the subject does not burn your car so that you say normal city mixed, change your air filter oil look at your water more or less the mileage you make but generally a normal km value
| 08.05.2020 13:56 | # 11 |
coyote26 |
my friend chıp says the thing, chptuning diesel vehicles, 30-35% of the gases increase 10-15% of power increase This software is not a tangible device or part that is tangible. a process that is connected to the brain of the vehicle. I do not know if there are any other benefits of using powerbox type devices that you call, but I do not know if there is a chiptuning in my own vehicle, and I recommend it to everyone who has a diesel vehicle. If you were in Eskişehir or Izmir, I would help you with this ...
| 08.05.2020 13:56 | # 12 |
greetings for diesel, recep master can help in topkapi.
| 08.05.2020 13:56 | # 13 |
bro |
[QUOTE = coyote26] my friend chıp says what chıpptıng diesel vehicles have 30-35% power increase in petrol between 10-15% 10-15% power is not a tangible device or piece This software; a process that is connected to the brain of the vehicle. I do not know if there are any other benefits of using powerbox type devices that you call, but I do not know if there is a chiptuning in my own vehicle, and I recommend it to everyone who has a diesel vehicle. Modifiye ... If you were in Eskişehir or İzmir, I would help you with this ... [/ QUOTE] First of all, I have never done this process before, I just heard what I heard and my impressions.And I heard that this work was done in 2 ways. -1500 TL around. Removed service etc .. It is a piece that can be easily disassembled and the original can be worn to avoid problems. |
| 08.05.2020 13:56 | # 14 |
If I have my 206 diesel installed, I wonder what this fuel situation will be? also how much will it cost me?
| 08.05.2020 13:56 | # 15 |
bro |
Is there any change in the final speed? Can you say I saw 200-210 after the chip when I was making a maximum of 180, or is this chip-software event used to get high torque at low gears?
| 08.05.2020 13:56 | # 16 |
It reduces 0-100 by 2 seconds. It carries the 70-hp vehicle to the range of 88-90-hp ... intermediate accelerations are noticeable. I heard that it has a positive effect on the fuel ...
| 08.05.2020 13:56 | # 17 |
so what is the price? what does this job explode on us
| 08.05.2020 13:56 | # 18 |
coyote26 |
[QUOTE = bro] [QUOTE = coyote26] my friend chıp says what is called chipping diesel vehicles 30-35% increase in power between 10-15% power increase. a process that is connected to the brain of the vehicle. I do not know if there are any other benefits of using powerbox type devices that you call, but I do not know if there is a chiptuning in my own vehicle, and I recommend it to everyone who has a diesel vehicle. Modifiye ... If you were in Eskişehir or İzmir, I would help you with this ... [/ QUOTE] First of all, I have never done this process before, I just heard what I heard and my impressions.And I heard that this work was done in 2 ways. -1500 TL around. Removed service etc .. It is a piece that can be easily disassembled and the original can be worn to avoid problems. first of all it is in the form of 2 you mentioned but more software is used instead of changing the brain because the service is not realized, even if the software is made, it does not matter if you connect it to the PC, it is not the case with this software vs the ztn ... You said that I will apply it to the zero vehicle. it is efficient because the engine of the vehicle hurts. I have sent you a msg specially, you can talk to the authorized friend and make your decision ... |
| 08.05.2020 13:56 | # 19 |
phaselispa |
I had reno megane until 2 months ago. 2002 model was 1.9 turbo diesel and was chip. It was about 130 hp. Performance was really strange. There was an incredible performance. In fuel, I can compare as follows. Between 100 and 500 liters diesel fuel (with chip) between 500 550 and 1.4 hdi 206 (note: without chip) 100 TL ie 600 650 km. While there should be more difference between 1.9 and 1.4, I think there is no difference. I feel sorry for not paying much attention to megane, but I'm not sure if I'm doing any harm to it. There was no problem with megane. I think it is now but I don't know 700 TL. (By the way, the original rim of megane was 15 and I had 16 and 195/60/16. This is a factor that affects fuel.)
| 08.05.2020 13:56 | # 20 |
coyote26 |
Of course, the rim fuel affects a little bit .... I would recommend it to your 206. Whatever car I buy, I will do it because the real power of the car is revealed ... ... the software has no direct harm to the car Now why it is not at the original time then we have friends to say then My answer is that the car brands are hurting to the markets and it is a segment event.This is my horse. ...
