Chip Tuning Secret and Ecu Optimization
08.05.2020 14:00 # 1
In order to understand Ecu Optimization application, you first need to know where and how optimization will take place. This optimization will take place in the ECU (Engine control unit) section. The feature of this application is that the engine will not be physically modified in any way. Only the chip (Flash EPROM) containing the information required for engine management will change. The original program will be read, carefully optimized, and the new program will be installed.
We need to go into a little more detail to remove the curtain of this work…
The history and benefits of ECU
The rapid development of technology in the last 20 years has not passed through the automotive industry. The automotive industry has made the most of this evolving technology. Undoubtedly, they have been the most profitable and most beneficial car users. We see the best examples of this thanks to high performance engines in new cars, low consumption, excellent handling and superior safety. Today's cars are equipped with Electronic Engine Management Systems. Whether with carburetors, central injection or common rail multi-point injection systems, these Engine Management Systems increase efficiency considerably… The most notable development in this period was the emergence of the undoubted Engine Control Unit (ECU).
What is ECU?
What is ecu
The ECU (Engine Control Unit) is installed in the engine compartment of the car or somewhere inside the passenger compartment. Its dimensions are smaller than a tape recorder. This small device contains more than one microcomputer and provides the most efficient management of the engine in changing conditions. These microcomputers run a program contained in an EPROM chip. The ECU is responsible for all engine management and controllers, and constantly monitors the engine's operating conditions, calculates parameters and continuously adjusts variables. All these adjustments take place hundreds of times within one second, taking into account the load, speed, environmental variables (air temperature, air density, motor temperature, barometric pressure, etc.) of the engine. All these measurements include pressure, temperature, speed, speed, It is possible to make variables such as…, with a deviation of one billion, by hundreds of sensors in the engine… The ECU detects these values, then finds the relevant values from the map in the EPROM, and ignition timing, optimum fuel quantity, turbo pressure, emission values, etc. calculates and implements the variables… All these processes take place in terms of one thousandth of a second…
alıntıdır
emrah 2009-01-09 16:25:04
