chills on first departure
08.05.2020 15:41 # 1
DRIVER34
hi everyone first
My car is a 2005 model307 1.4 xr 16V vehicle in the morning, so when the engine is cold, it starts trembling at the start, as if it was caused by the engine's ears, I guess there is a problem with the clutch, especially when I switch to the gear.
the albaydemirc 2011-06-24 16:18:38
08.05.2020 15:41 # 2
forewer_fb
I had a similar problem with me, it was caused by the engine's ear. Is there the same problem with high gear low speed?
08.05.2020 15:41 # 3
DRIVER34
the tremor that occurs when it uses low speed normally but not contradicting from time to time, does not have a big knock.
08.05.2020 15:41 # 4
forewer_fb
I say lift it up in the fiber and look at the engine heads, sometimes the upper or lower rubber part may be broken.
08.05.2020 15:41 # 5
DRIVER34
At first, I was using gasoline, it was taken from the fulle, I wondered if I should clean the throttle, and then, from time to time, when I had a problem with the gear shifts, I was in particular clutching from 1 to 2.
08.05.2020 15:41 # 6
DRIVER34
Let me take a look at the industry in the evening ..
08.05.2020 15:41 # 7
axi206
In the departure that I know of, it makes the tilt at the flywheel.
08.05.2020 15:41 # 8
DRIVER34
I haven't thought of it, but I guess I don't want to accept it as it does the volant option when the vehicle is cold :)
