Chills !!!!!! Important!!!!!
08.05.2020 21:16 # 1
Alparslanemett
When I bought a Peugeot 206 I had a car, the front augers were flat, I was disturbed, I replaced it with 2 new augers and 2 shock absorbers, but when it was loaded into the gas in all gears (the gear does not do when it is idle), it knocks down from the axle, we changed the axle, the axle changed, the rot has changed but still continues It is. No visible malfunction axle new shock absorber new spring new
08.05.2020 21:16 # 2
cemsezgin06
Have you looked at the motor ears, brother.
08.05.2020 21:16 # 3
Alparslanemett
I did not, but thank you for the information.
08.05.2020 21:16 # 4
cemsezgin06
Have the engine's ears checked. It may be due to them. Even the shaking glasses in my car were shaking, the gear knob was playing excessively.
08.05.2020 21:16 # 5
KILIC
The helix may be installed upside down and the master can also make it from it.
08.05.2020 21:16 # 6
pusutr
I guess this is due to swings. It happened to me too. was saying axle ears etc etc. he was off the swing. If the swing bellows are torn, replace it. but before that, it is a good idea to have the shock absorber screws tightened or installed properly.
08.05.2020 21:16 # 7
(E)motion
First of all, I recommend that you have the parts of your vehicle checked to ensure that they are fully and correctly fitted, and then replace the engine underrun (also known as the fork beam), the upper right engine mount and the upper left transmission mount. Your problem will likely be solved.
