Child lock problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:17 # 1
kemal26
Child lock is closed, I can open it from inside or outside. Does anyone have an idea what should we do?
08.05.2020 21:17 # 2
kemal26
Neither helpful nor give an idea close this site. The door of the newer car broke down. No peugeot officials can answer.
08.05.2020 21:17 # 3
ertugrulll
I don't understand what kind of child lock is. The child lock is opened from the outside. Your problem is the door lock. You are more than happy to open a subject.
Can you look at the title of the topic?
Child lock is closed, it cannot be opened from the outside ????
What is the problem? Let me think !
Your door lock is not broken, or your cable passing through the bellows inside the door is broken, or broken in the plastic part that unlocks the door. There are many reasons. The locker will remove the back seat from inside and remove the upholstery of the door and open the door in such a way. Then the problem will be understood. It is not something to be captivated. You go and RISE immediately, you say it will not work. I was a Peugeot in 2011, I joined the form in 2012. I have been in this form for 7 years, it was the first time I saw your change.
This is not the peugeot general service, ALO xxx roadside assistance, ALO FIRE LINE 177 or LOCKER RAMIZ DAYI 05xxx at all. This is a community of people who have a problem with their normal vehicle, who helps others if they have the same trouble, give their minds, say their ideas, try to meet, mingle, and try to help each other. NOT A PAINTING CUBE. EXTREMELY EMERGENCY, GO TO THE AUTO LOCKER.
The same is happening on the rear tailgate of 206+ vehicles. Trunk opening is opened by pulling the wire out of the rear sponge, pulling the wire.
08.05.2020 21:17 # 4
kemal26
First of all, thank you for giving a reply as a servant of a positive or negative God. Since the vehicle is zero and under warranty, they made it with a half-hour operation at the authorized service. I know that the child lock is not unlocked from the inside. I wrote that way to say that the door never opened. Because if I did not write that way, if I said that the door does not open from the outside, then they would write why you would not try to open it from the inside. My problem is solved, thank you.
25.12.2021 18:51 # 5
Mr.Engineer
I have that same problem. How did you solve it sir? The master said that we need to change the lock completely, but the lock was intact, only when you turned it for the child lock, the door wouldn't open from the outside.
25.12.2021 20:18 # 6
saslanboga
Sir, lay down the back seat, separate the plastic cover on the pole a little and remove the door seal. You will see the red place where you activate the child lock through the opening. Turn it with the help of a long screwdriver. Open from inside. Then, for the problem of not opening from the outside, lubricate the door lock and the black rotating part at the bottom with WD 40 or liquid grease. Good luck with
25.12.2021 20:46 # 7
Mr.Engineer
Thank you sir, I'll have a look
