Chest lift
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:03 # 1
ostrah
Greetings,
When I left my 2011 3008 vehicle to the service last year, the vehicle remained in service on the feast, I think half finger between the chest and the middle ventilation got up, I showed it to a couple of places in Ankara, diagnoses such as the need to remove and look at the whole chest, already a vehicle with a trim sound, it would be all bad if it was removed. I did not intend, I did not manage to add pictures, I could not find the man of this work in Ankara, is there a master or solution suggestion that you can understand? Thanks
08.05.2020 21:03 # 2
If you compress an authorized service if you are well-maintained vehicle Peugeot turkey parts in good faith they meet 60-70% of the zero babe teacher whether you can make money on the rest of you. Otherwise, it would be most reasonable to have a clean chest. If you are a good master, it will not be worse, even if you have extra sound insulation in some places and if you fix the cables hanging from the left to the right, you will be more straight. Of course, the important thing is to find a good master.
08.05.2020 21:03 # 3
HasGur
Outside the central ventilation frame, it should be a separate piece from the L-shaped chest body that starts from the right of the gauge shield and joins with the chrome piece to the right of the radio. Is this the place that rises up, or is there a problem on the main body behind this piece?
I think my servicebox account is blocked, I could not look for a separate piece, but if a friend who has a membership or a docbackup on his computer looks at it, he can give clear information about this piece.
08.05.2020 21:03 # 4
ostrah
https://resmim.net/f/VuUOf9.jpg
08.05.2020 21:03 # 5
ostrah
This is exactly the situation I was able to install at the end, the vehicle is not serviced so it is difficult to compress the service, I did not know if it is necessary to change the chest again. ostrah 2018-10-18 11:25:00
08.05.2020 21:03 # 6
HasGur
[QUOTE = ostrah] I was finally able to install it, this is exactly the situation, the vehicle is not serviced so it is difficult to compress the service, I did not know if it is necessary to change the chest again. [/ QUOTE]
Although the service is not well maintained, it is useful to contact an authorized service first, as Soner wrote. If the vehicle has not received an impact that affects that area from the front or sides in the past, if the chest has not been removed and reinserted, they may be interested because there is a visual distress that could not be a usage error. If they are indifferent, it is better to add clear photographs taken from different angles before you intervene yourself , mention the authorized service you are talking to, write to the manufacturer and wait for an answer.
08.05.2020 21:03 # 7
ostrah
Thanks, which authorized service do you recommend in Ankara?
08.05.2020 21:03 # 8
I recommend Fatih Peugeot
08.05.2020 21:03 # 9
Tarkan
The same problem happened with me in the same place. I would be very happy if you could give information about your solution in the future. I thought that it could be restored by putting something on the glass and compressing it and applying pressure.
08.05.2020 21:03 # 10
ostrah
[QUOTE = Tarkan] The same problem happened in the same place, I would be very happy if you give information about your solution in the future.
I will let you know if I solve it Thumbs Up
