Chemical Products Recommended by Peugeot
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:08 # 1
hasimayaz
RECOMMENDED PRODUCTS MECHANICAL 1 - CLEANING PRODUCTS uses - data index: products Part No. provider (s) gel liquid D2 DECAPLOC9731.25 FRAMET for de-rusting non-metal gaskets and seal planes DECAPJOINT9732.11 degreaser SD 140 D3 9736.57 - 2 - SEALING PULSE endis: products Part No. the sealing of the threaded connections and the brake (s) of the provider (s) must remain removable E3 FRENETANCH9732.48 FRAMET sealing planes and bushings E4 FORMETANCH9732.46 tightening of the bearings, rings, sockets, liners, intermediate joints, pulleys and strengthening the threaded connections E5 SCELBLOC9732.47 with maximum efficiency sealing and braking of nuts and studs E6 FRENBLOC9733.10 sealing of seal planes in replacing conventional gaskets: E7 FORMATJOINT9732.45 sealing pores of the seals: aluminum-based E8 POXY MATIC9732.17 remains exposed to vibrations and high pressures, after the seal of the seal planes of aluminum-based E8 POXY MATIC9732.17 remains soft after sealing of gasket planes exposed to vibrations and high pressures sealing (excluding ball joints) E11 ECHAPNET9735.01 strengthening of fixed connections: sealing E12 AUTO FORM 5499733.68 against atmospheric events durable flexible seal E13 AUTO JOINT CLAIR9731.61 sealing of the covers on the hard brake drum and cylinder head of the bolt threads E14 LOCTITE 2759735.58 sealing of the seal planes in replacing conventional gaskets E15 FORMATJOINT9732.45 3 - RUST REMOVER uses - data index: products Part No. provider (s) oxidized or corroded parts and rust remover (spray) F1 9731.68 SADAPS - BARDHAL 4 - OILS uses - data index: products Part No. provider (s) high-adhesive grease: grease oil especially for transfer systems G1 MOBIL 5259732.03 CEPAC high-adhesive grease: grease oil that can be used in mechanisms subjected to water spray, high pressures: grease oil for rods of exhaust manifolds MECAGRAISSE9733.69 G2 LUBRITHERM G2009733.44 oil for harsh conditions: oil for water spray, high pressures, temperature-exposed mechanisms G3 LUBRITHERM G2009733.44 temperature-resistant grease: grease for gear parts (spark plugs) fitted on the cylinder head G4 LUBRITHERM G2009733.44 Multi-functional grease: grease for daily work G6 9735.72 CEPAC Special grease: grease for the bearings of anti-roll bars G7 ESSO NORVA 2759734.14 Special grease: direction for mounting the abs brake system sensors grease grease G9 ESSO NORVA 2759734.14 oil Molykote G. Rapid plus: grease oil for the mounting of cylinder head screws G10 MOLYKOTE G9732.05 grease oil for surfaces G12 MOLYKOTE BR2 + 9731.89 Multi-functional grease (drive shaft RZEPPA) (steering rack) G13 TOTAL N39459735.D2 5 - MINERAL HYDRAULIC LIQUID uses - data index: products Part No. provider (s) hydraulic fluid for electric engine hood M1 ESSO UNIVIS J329735.57 CEPAC
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
