Checking the water level
08.05.2020 18:29 # 1
Thomassee
Guys, how do we do this in 206?
And where is this water filled, from the plastic cover on the left?
Thanks.
08.05.2020 18:29 # 2
berkayakulker
The vehicle already has its own sensor. But if we are talking about the wiper water, then that blue cap on the left ...
For the engine, it is mostly with a yellow or black cover and close to the right headlight.
08.05.2020 18:29 # 3
samet206
Just as you can reinforce it from the upper left canister, there is a dash on the container for the level, if it is old or if you can't see the tin, it is enough to fill it with the eye decision if it is not full of water.
samet206 2014-04-25 15:50:50
08.05.2020 18:29 # 4
Bugra
Now friends right left sides are a bit complicated. When you sit in the driver's seat, the blue cover on the right front is glass water. There is a protruding part when the lid of the black cap with a plump shape on the left side of the left is opened at the normal level. When looking from the outside, it is the middle level of the fat canister. of course I'm talking about 206 hdi i don't know how gasoline
08.05.2020 18:29 # 5
Thomassee
I'm sorry I didn't think of it Big smile
I'm talking about coolant, not wiper.
I thought when opening the hood for the direction, not the driver's seat.
Vehicle diesel, by the way.
It would be nice if you show it on a motor picture.
Teşekkrü on.
08.05.2020 18:29 # 6
berkayakulker
[QUOTE = Buğra] now friends right and left directions are a bit complicated. When you sit in the driver's seat, the blue cover on the right front is glass water. There is a protruding part when the lid of the black cap with a plump shape on the left side of the left is opened at the normal level. When looking from the outside, it is the middle level of the fat canister. of course I'm talking about 206 hdi do not know how to use gasoline [/ QUOTE]
Since we cannot put water from the driver's seat, of course, we will look from the front of the lion. LOL
08.05.2020 18:29 # 7
Bugra
Brother I gave up telling Dead
08.05.2020 18:29 # 8
berkayakulker
[QUOTE = Buğra] brother I gave up telling Dead [/ QUOTE]
Didn't we offend hodja? Confused
08.05.2020 18:29 # 9
Thomassee
Don't be angry, my friends, no ??
I'm putting pictures here.
http://i.imgur.com/5uq9wskl.jpg
I know blue wiper red cooling is it wrong ??
I want to ask, what is the correct level of them, half or half of it?
And I don't know what these greens are. Brake fluid or something.
Good evening.
08.05.2020 18:29 # 10
Thomassee
Let me add it as follows.
08.05.2020 18:29 # 11
berkayakulker
Wink they are shock absorber plugs teacher ... when you lift the hood you will see the bolts
08.05.2020 18:29 # 12
Thomassee
Thanks buddy Thumbs Up
How do we level these fluids, is it moderately good ??
08.05.2020 18:29 # 13
berkayakulker
[QUOTE = Thomasse]
It is ideal to have max and min in the middle of the writer in the canister with engine water.
If you want to fill the wiper water to the brim, I don't think it will be a problem. Wink
08.05.2020 18:29 # 14
barishrocker
When the wiper puts too much water, it will remove more. While I was putting water once, I looked at it. I thought it exploded. I went to the service, he gives more out, said relax
As for the other one, it will be between the values written as max and min as it is said.
08.05.2020 18:29 # 15
samet206
The places marked in green have nothing to do with water. They are shock absorber heads. Red marked ground cooling water, blue cover will wipe the water on the top, but I put it in the memorization for gasoline, it is wrong. It was tested, it was tested that it should have not been a problem in this way.
08.05.2020 18:29 # 16
korkusuz202
Friends, nobody knows innately .. Shame not to know is not shame to learn :)
you can fill the wiper water until it overflows, but I think that you can fill the water or antifreeze for cooling, add a little bit in half ... no need to add more.
Here I showed the necessary explanations on the PICTURE. I added the necessary ones.
korkusuz202 2014-04-26 19:14:56
08.05.2020 18:29 # 17
Thomassee
How do we make the brake fluid?
How long does it take?
By the way, I realized that our Pugs are very comfortable in terms of maintenance LOL
08.05.2020 18:29 # 18
korkusuz202
so ... look at the open lid .. don't worry if it's full to the tip or not under half of it ...
08.05.2020 18:29 # 19
rolandgarros
min. on the drum with cooling water. and max. phrases are included. please not below minimum or above maximum. It will overheat the container to the brim. we have to act with the logic of excessive harm. please do not have full antifreeze. If you fill antifreeze and water mixed, antifreeze will do its job. Cold winter months may cause freezing when full antifreeze is put. antifreeze can only show its effect when mixed with water.
08.05.2020 18:29 # 20
ahmed206
Compared to gasoline, the location of the cans of cooling water remains at the opposite corners.
Today, after the circulation has changed, my master worked almost 1 hour to remove the air inside the system. I am also aware of the location of the two worshipers, and even though we were using them, we could not finish the air in a certain way and left the car again. Today I will sleep without a car.
