Check Bipper Tepee 1.4 com.plus gearbox
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper tepee
08.05.2020 20:33 # 1
balya
When my semi-automatic vehicle in the 2010 model 110 thousand km makes a lot of stop in traffic, it is malfunctioning, "Check the gearbox, look at the user manual." Sometimes it repeats frequently, sometimes there is no problem for 3 months.
08.05.2020 20:33 # 2
hayalcik
Your print pad is running out. you have to change it. they need to lower the float to replace the press brake. when lowered, you also changed the gearbox oil.
08.05.2020 20:33 # 3
KILIC
Hodja, when you get up and stop when you get an opportunity, take it for n rest and make the transmission without overheating.
24.06.2020 12:19 # 4
Bitirdibeni
I am having the same problem. I'm always on the road. Is there a solution to this fault?
24.06.2020 12:21 # 5
Bitirdibeni
Is your fault solved in this way?
24.06.2020 15:39 # 6
Have the transmission oil level checked, sir. There may also be a problem with the oil cooler. Of course, first have an original device check the fault codes.
06.11.2023 18:22 # 7
Barisince52
Sir, has the problem been resolved? I've had the electrical system checked, the battery checked, and the gear lever, transmission fluid, pressure plate, and pads replaced, but the problem persists. It's especially problematic when shifting into reverse and shifting to "N" (N-N) and the car recovers in 1.5 hours. I think it's due to overheating, but my car is a 2009 model, and the mechanic says it doesn't have an oil cooler.
16.03.2024 09:53 # 8
BipperFan
Friends, has anyone found a solution to this problem? This problem definitely occurs when the vehicle warms up, and I never experience this problem when the temperature is 2-3 degrees, but I start to experience it a lot when it is 14-15 degrees or warmer. There is no problem when I don't get into stop-and-go traffic and continue, but whenever I get into stop-and-go traffic the car shifts to 1st gear, that's when I start to experience this problem. Now I especially put the car in neutral when I'm about to stop. Especially when I come to lights etc. I always let the car sit in neutral while waiting, and when the light turns green I shift from N to A and continue. I still haven't found a full solution. I've replaced the gear actuator, heater system, transmission cooler, and even all the fluids, but I continue to have this problem. They especially told me to change the robotic transmission fluid, I changed that too. No, I can't find a solution.
