Chauffeur puddle Solutions
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:24 # 1
repropark
Hello friends. In most of our vehicles, we have a problem of accumulation of water in the driver's room. If this happens primarily in the winter months, it may be due to the wear of the heater core connections. A very descriptive and illustrated narrative about this subject was given by our text friend. http://forum.peugeotturkey.com/forum_posts.asp?TID=20250&title=solama-water-vehicle- vehicle-Iine-szmas-problemibo that there is a heating system discharge from this link can solve the problem. Yesterday I was enthusiastic about this puddle on me, and I rolled up the sleeves to solve the problem, but there was no leakage in neither honeycomb nor plumbing. to investigate where the water came from, I closed the door and started to hold water with the hose, did not take the door wicks, the air conditioner under the windshield to the air intake panel and the water started to flow into the car, when you open it you will see the bonnet opening rope, there is another empty hole in parallel, I think there is something like a plug, so many of you in the car, check those who are not plugs, blind that hole as soon as possible because the water leaking from it flowed directly onto the bsi and dropped from there to the floor, I tried to find the leak and I gave the water too much, and the water was full As soon as I started doing things, I disassembled bsi and cleaned it with contac cleaner (Spray) and dried it with air (the air should not be hot) and it got better. It is announced to friends who have leaks in the vehicle, the problem has been solved, I will say that it is water, you will be bsi. Best regards.
08.05.2020 16:24 # 2
Get well soon. Ingestion of water into the interior is still solved, so the deterioration of BSI would be very expensive. First of all, this part of everyone's vehicle should be maintained. I always look at that person when I open the hood. I will examine whether there is a puddle of leaves or sludge deposits.
Thanks for sharing.
08.05.2020 16:24 # 3
Eyup Duygun
Bsi repair is not too much, the change is in the process of getting worse work key coding etcvs .... br>
Wiper, windshield closure, locking etcvs..de problems in these vehicles should be checked as soon as possible.
08.05.2020 16:24 # 4
repropark
beware of friends who have this type of abnormality and have problems, rotting, oxidation and burning in the circuit, etc. If it happens, you will not be able to repair it, you will instantly become 1000 liras.
By the way, Eyüp Bey, how does chip application to 1.6 gasoline 307, what does it cost, what benefits do we see? I've been wanting to talk about this for a long time, note: my car is automatic gearbox.
