Charger
08.05.2020 18:39 # 1
phoenix.1905
I went to the veteran because of excessive tremor in LPG today. Gas adjustment was made and it was seen that it improved in the test drive, after 100m, the car started to sound like tark tark as if it had excessive trembling in both lpg and gasoline, as if it was stapled. They said they looked, the Charger is overcharging. (There was a smell as well as measuring and the tire burned) Another master came. It replaced the spark plug and coil. The study has improved. They measured again, the measurement value was 15 or so. They said it is overcharging again .. they want 200TL for the charger. My question to you is
What problems do I have if I do not change the charger?
I have xenon fog lights in my car, does it benefit or harm when I turn them on?
08.05.2020 18:39 # 2
kuscu38
Charging dynamo will cause consequences such as overheating in the battery, burning, explosion or burning in the electrical installation, but not suddenly. If you go to the industry and go to 2-3 dynamists randomly, both the price will decrease and separate solutions will be created to make the problem simpler. maintenance may have come in time ...
08.05.2020 18:39 # 3
phoenix.1905
Today, the gas cycle of the vehicle has been at 500-600 rpm. At that time, the lights of the display panel (headlight was on) increased and decreased. I think the charger is overcharging. However, I asked a few friends that instead of changing the dynamo, it would be enough to change the diodes in the dynamo.
08.05.2020 18:39 # 4
phoenix.1905
Another electrician said that the connectors inside the dynamo had to change. I need to open it and look at it, up to 150 lira.
08.05.2020 18:39 # 5
kuscu38
[QUOTE = phoenix.1905] Another electrician said that the connectors inside the dynamo need to change. Open it up and look up to 150 lira.
Just as I said, you can take care of them, they are at least relaxed, they cannot be understood without opening.
