Changing the Partner's horn
08.05.2020 18:05 # 1
baybaba
Greetings I couldn't get used to using the Partner's horn, or it seems very difficult to me, my previous car clio was also very easy to use with his fingertip, you can use the horn very easily. The event is over until I steal it, my fear is really horn
the accident that I will prevent by pressing, it happens to me because of the horn I couldn't play in time, can we move this horn, can we get the signal like the clio?
08.05.2020 18:05 # 2
Aziz
His nail is damaged over time, the master from whom you can get it is very rare.
for the other issue, if you can find a smart electronics electronics
08.05.2020 18:05 # 3
Alicilik
[QUOTE = baybaba] Greetings I couldn't get used to using the partner's horn, or it seems very difficult to me, I was able to use the horn very easily even with my fingertip in my previous car, in this clio you do not steal, you find the exact location and press it in the middle of the steering wheel with all your strength. it is necessary, often the event is over until I knock the horn, my fear is really horn
1 line of the horn is transmitted to the steering wheel with com2000in airbag coil.
First of all, you can remove the airbag part of the steering wheel and see if there is a lack of contact. Then let's look at a solution
08.05.2020 18:05 # 4
baybaba
I never thought that the horn could be related to the airbag,
the airbag light comes on every once in a while, then it gets better again,
then I think something about that, let me take a look,
08.05.2020 18:05 # 5
Alicilik
[QUOTE = baybaba] I never thought that the horn could be related to the airbag,
Have the com2000 winding checked. Airbag and horn canceled once mine broke off.
