Changing the Information Panel Color
08.05.2020 15:58 # 1
tigerland
You can change the information panel color very easily. to find the colored tape you need to do .. after taking the colored duct tape blue-green-yellow duct tape on the kipa after removing the top cover of the panel and removing the 2 Tors key information display. We remove the electronic circuit by separating the panel from the gears and take the template with orange inside and there is a template with a white background and we paste it on the blue (light that changes according to the color). then we mount it in the same way and the information display is the color you want. The color template that determines the color .. The result .. :)
this is the most practical way. otherwise, it is necessary to use colored led. :))
Uploaded with ImageShack.us
08.05.2020 15:58 # 2
Brother looks very cool (tikican like I said: P) but really cool and simple practice thank you for your sharing. Now the screen will not have a blue color (red speed etc) orangeish reddish color, napcan them :)
08.05.2020 15:58 # 3
tigerland
I did it in the same evening I did blue, I ripped it back, I did orange :) Blue beautiful nice eye-catching shape Whatever cool but you can change the color in a practical way only with the band. blue looks beautiful, it just takes a look, so I just turned orange :))
08.05.2020 15:58 # 4
You did well ERbin, I think it was a good expression for friends whose original is beautiful but who want a difference :)
08.05.2020 15:58 # 5
kayas
[QUOTE = Erbin] You can change the information panel color very easily. to find the colored tape you need to do .. after taking the colored duct tape blue-green-yellow duct tape on the kipa after removing the top cover of the panel and removing the 2 Tors key information display. We remove the electronic circuit by separating the panel from the gears and take the template with orange inside and there is a template with a white background and we paste it on the blue (light that changes according to the color). then we mount it in the same way and the information display is the color you want. The color template that determines the color .. The result .. :)
What should we do when we want to install LEDs. When I replace the leds with the original bulbs, is the voltage value required for the original bulb and the voltage value required for the led? I wonder if there is a problem. It is known that the bulbs constantly break down, at least the leds go longer. 50krş something I call a light bulb, but changing it constantly is annoying.
Also, if the orange paper on the back changes if the screen is faded, is the problem resolved?
08.05.2020 15:58 # 6
Erbin Maşallah `` Makgaygir '' Like Vesselam From the Steering Wheel Cover to the Air Duct in the Bumper ... I Say If I Throw A Hand At Ours ...
The Light Efficiency of My Information Panel Is Too Low ... Acieln Help Erbin Gülme
08.05.2020 15:58 # 7
tigerland
Thanks, Colonel, I am playing with the left side of the vehicle as a matter of time in my boredom. You can buy a led 30 cm 5 TL from the electronics shop, I think. Cut 2 rows to the panel, put the ball back to my solder + - mount it back :)
08.05.2020 15:58 # 8
[QUOTE = Erb's]
[/ QUOTE] Wow Brother ... Gülme You're Saying Super Super, But But But So, Not Money In Material,
How can I get rid of it? Gülme
08.05.2020 15:58 # 9
tigerland
[QUOTE = AlbaYDemircaN] [QUOTE = Erbin]
I take a picture and show it under the subject.
G3 infantry rifle 1 min. I think I was taking it apart, I guess there was a rule in the military or it was a total of 1 min.
08.05.2020 15:58 # 10
Thank you Erbin will be Zahmet ...
It would be great if you make a nice illustrated narration ... Thumbs Up
08.05.2020 15:58 # 11
hmm Nice Göz Kırpma
the cecol 2011-08-17 13:10:53
08.05.2020 15:58 # 12
[QUOTE = berkekk]
hmm Nice Göz Kırpma
Berk brother, why do you quote the pictures instead of writing a direct message to the bottom. Göz Kırpma
