Changing lights to blue on display
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 14:59 # 1
The application I found in a foreign forum and I think it will be useful. I can translate exactly .----------------------------------------------- ---- Inserting the screen (After removing the battery terminal) There are special tools to do this, but I only used a screwdriver. First I inserted it into the hole and then gently lifted it with another one. Then I applied this process to the other side. After removing it, you need to insert all the screws on the back unit. (with torx T10) Pictures of the tools I use: After removing the screws, the plastic cover will be separated and you will be able to reach the indicator hands. To remove the hands, lift it slightly by rotating it counterclockwise. Never use any vehicle. In the meantime, note the previous position without removing it so that the hands do not shift. Then we can remove the plate below the hands and see the electronic circuit underneath. The places where the LEDs are are taken in the round picture below. A few additional notes. If you do not have the ability to solder, get it done to someone else. You need a very thin tip soldering tool for this process. Do not apply the soldering tool for more than a second when inserting and installing the leds. otherwise you can damage the leds. I even melted 2 of them on my first try. Now, remove the old leds by using the soldering tool. We have to do this gently, because we must not damage the contact points. After removing all of them, we can replace the new LEDs in the same places. The LEDs work only in one way. Therefore, pay attention to the poles. When you look closely at the Led, you will see that it has a very small circle on one side. This part will come to the place written with K in the electronic circuit. In other words, the part that is gentle will be on the side that says K. You can see the pictures below. To save time, I wanted to give it a try without putting the screen back on. As in the picture below. If everything is on the way, we follow the screen as we disintegrated and expect it to be dark. Here are the results (day / night) koliva2010-12-09 11:10:26
08.05.2020 14:59 # 2
very nice ... health to your hand ...
08.05.2020 14:59 # 3
muratgulen07
It can be useful to friends .. but not to me :) I don't have that talent.
08.05.2020 14:59 # 4
juventa
I think I wear the dials incorrectly so I will not be able to connect or I can connect the leds. & nbsp;
08.05.2020 14:59 # 5
if they are not knowledgeable, they will get heat in the press :))
08.05.2020 14:59 # 6
Yusuf Tekoglu
In fact, if we do the LEDs on the hands without removing them, the hands will turn red and a more beautiful image will appear.
08.05.2020 14:59 # 7
I really like it
08.05.2020 14:59 # 8
Muhammet CAKIR
it is very nice but & nbsp; I know my leds are solderless? besides normal 206's Muhammet ÇAKIR 2011-01-25 19:34:05
08.05.2020 14:59 # 9
murtycan
friends, I just want to make the needle white at 206, where can I do such a process?
