Changes suggestions for 307
08.05.2020 17:53 # 1
hexen
Dear friends, I made a list of what I wanted to do for my vehicle. I need your experience and advice.
2004 307 XS Aluminum Gray
First of all, I don't like to spoil the original image of the vehicle, but I want to have changes that I can enjoy.
1-I love the original rims. Do you have a drug suggestion for the stains on it?
2-I think Michelin primacy hp in original sizes of tires
3-Sports bow 3cm
4-Is it better quality shock absorber monore or something?
5-The vehicle is used in both gasoline and lpg. My wife is using LPG for saving.
6-Arçık air filter kit or just a mushroom filter
7-Does the complete exhaust undergo an inspection? How much does it cost? Which good silencer on my mind would you recommend?
8-Do you recommend oil additive (I do not have any engine problem in terms of failing)
9- I think Brembo front disk
10- Ceramic pad for both front and back
Do these counts turn on the malfunction lamp or will it cause obvious damage to the vehicle?
Thank you very much in advance ...
heXen 2013-08-21 01:12:32
08.05.2020 17:53 # 2
hexen
Guys, did you have an idea that I wrote so long?
08.05.2020 17:53 # 3
hexen
[QUOTE = onurazgin] Let me get on the rims, you can clean the rims with cellulosic thinner. however, it takes a long holding varnish.
michelin is a good choice when it comes to tires.
I recommend coil over as a suspension. If you have a budget, get an air suspension.
you can try performance spark plugs, but your fuel will increase anyway.
The open air filter is more suitable if you have an intention of getting noise from the air filter.
exhaust without catalyst does not pass the inspection. It may happen if you can agree with more measurement sites related to exhaust measurement values.
I would definitely not recommend oil-fuel additives. Instead, get your car raged and get the best fuel.
The brembo caliper cap looks nice on the caste. unnecessary expense for ceramic linings 307.
Thank you so much
rim tire subject ok
Suspension coil over a bit exceeds me I guess :) I think I will buy sports bows I do not want to get to the ground 3 cm is enough
I think that the spark plug does not increase in engine noise starting and quiet use
Air filter is not always, I would like to hear the sound in between. I think actually my aim is to breathe a little more and make the car more efficient if it is in a bit.
As exhaust there is no problem in the inspection, my wife is in peugeot service :) but I can get a good final muffler recommendation, my goal is not to blow out the exhaust gas more efficiently.
you are right in oil and fuel
brembo caliper not hawk I meant the discs in peugeot you would recommend you want to use it with the ceramic pad
08.05.2020 17:53 # 4
hexen
http://www.peugeotmarket.com/peugeot-307-16-on-fren-dıskı-spor-brembo,pr-1526.html
This product...
08.05.2020 17:53 # 5
hexen
I wrote wrong on the Peugeot market :)
